Injector swap question
  • capucastro
    • May 2007
    • 512
    I search for that without any luck....sorry if it an answered question...
    Do I need to change the Fuel Pressure Reg If I swap my injectors with a set of 17.5lbs ones (m50) and swap to a MarkD chip (17lbs and 93 oct)??
    I think the M30 comes with a 3.0bar FPR, but I'm not sure. That could work?
    E30 325is '89
    E46 330ci '04
  • Jordan
    • 12916
    Don't swap regulators, all it does is confuse the ECU and lengthen the adaption process.
    https://mtechniqueabs.com/
    • capucastro
      • May 2007
      • 512
      Ok.. But Do I need a new one (I think BMP has a good one) , or can I use the stock one?
      E30 325is '89
      E46 330ci '04
      • mikeedler
        • 6707
        i personally cant see how the M50 injectors could possibly be good for the M20. the spray pattern is setup for for a 4 valve head. so it is going to be spraying completely wrong for the shape of your intake port. right?
        I am not sure, but wouldnt the M30 injectors be better?
          • 34844
          it's not a matter of "made for a 4 valve head". they are just design II/III injectors - which were used on all sorts of motors (including lots of 2 valve Fords).
          • Jordan
            • 12916
            As Nando said, and in addition your stock FPR is fine.
            • capucastro
              • May 2007
              • 512
              Thanx man
              E30 325is '89
              E46 330ci '04
              • Joe318is
                • Sep 2005
                • 6451
                Dont use injectors from an 83 84 533i [low ohm]. They will work in an ETA motor but not an I motor.
                Originally posted by vlad
                  • 37833
                  I have M50 injectors with a chip and M30 AFM, stock FPR.
                  Grover Beach, California
                  BimmerHeads.com
                  • mikeedler
                    • 6707
                    are they really the same injector? I am not doubting you, because I really dont know what fords you are talking about. could they have different attomizer nozzle things on them? I am in school over here, and we just went over that topic a week or so ago. They are 100% designed for a 4 valve head(the ones in a M50) they spray in a pattern that shoots a stream to the left and right. There is alot in the design of how fuel is sprayed(i know in a 20 year old motor) it isnt such a big thing.
                    any german mechanic would tell you not to use them because of that. once again, I am not saying it doesnt work, just questioning if it is not better to use the M30 injectors.
                    • capucastro
                      • May 2007
                      • 512
                      Do you Dyno'ed?
                      E30 325is '89
                      E46 330ci '04
                      • capucastro
                        • May 2007
                        • 512
                        The M30 19lbs Injectors are too big for the set up I want.
                        E30 325is '89
                        E46 330ci '04
                          • 37833
                          Originally posted by capucastro
                          Do you Dyno'ed?
                          I have not but I should do it soon!
                          BimmerHeads.com
                          • Jordan
                            • 12916
                            FYI... even if one of the BOSCH design II injectors are setup to fork the spray to the sides (which I doubt, but I'm entertaining the thought) I seriously doubt it would make a damn bit of difference in a running engine.
                            In a static environment you will see a wonderfully atomized cone of fuel. At the monstrous feet per second the intake charge is rushing by the pintle.. I just don't see the spray pattern mattering a damn bit.
                            • mikeedler
                              • 6707
                              yah, you must be right. the spray pattern has absolutely nothing to do with power or the way a car runs or anything like that, those stupid bosch engineers just make crap up.
