URGENT - Accident - where to tow?
  • Ahheck01
    • Aug 2004
    • 185
    Okay, so my brother's '87 Mtech1 325is met the rear end of a new Impala this morning. The impala took off (luckily) and we pushed the car to a side road. We need to decide if we can put it in my garage and work on it over the next few weeks, or if we should just take it in and spend a fortune having a mechanic do it.
    the front end is pressed in - the radiator support bar that goes across the car is pressed back a bit, and the radiator is pushed into the fan, which is now at an angle because of it. The car won't start because the fan is kinda pinned.
    We're fairly competent in wrenching - I rebuilt an OBD1 S52 last year and managed to get it to start on the first try after it was all put back together. That said I would need a lot of direction.
    So, is this something I can save money on by doing it myself, or is this damage that the body shop needs to address?
    TIA for any input! Pics will come soon, but we need to move the car soon!
    -Evan
    1992 525i 5speed: Sold :: 1996 328i 5speed: Sold :: 1997 540i 6speed: Sold :: 1995 M3ti 5speed: Sold :: 1997 328i 5speed: Sold ::
  • psloan
    • 9815
    Need pics. So, did you get the guys plate #?
    • Ahheck01
      • Aug 2004
      • 185
      No. We rear-ended him, so we don't want to make it a legal issue. We were rather lucky that he took off. Working on pics.
      -Evan
        • 34844
        you should replace the radiator core support, and have the car put on a rack to check for straightness at least. a new core support is around $400 (used is less, but you have to cut it off), and the job to put it on should be about $500. at the very least, you'll want a real body shop to do that, but you can probably do the rest yourself.
        or you can try to straighten it out, but it will never be quite right.
        • PiercedE30
          • Apr 2005
          • 4220
          I can probably get you a good core support if you need one.
          My 2.9L Build!
          • Ahheck01
            • Aug 2004
            • 185
            I'm sure we'll be talking soon.
            First pic:
            • M42Technik
              • 9781
              -Evan
              Oh I see now, it would have been on you guys to fix his Impala...good luck repairing it!
              Reminiscing...
              • Ahheck01
                • Aug 2004
                • 185
                Yup. Pic two:
                • JGood
                  • Jan 2004
                  • 7959
                  Since when won't an engine start due to the fan (which is on a clutch) not being able to spin?
                  I'd be concerned about that.
                  Need some close ups of the front area - but it looks like it may be easier to weld in a new upper rad support. At least you missed the bumper, so the mounts didn't compress and possibly bend the frame rails. I'd rather replace a fender or hood then deal with a tweaked unibody.
                  e30 restoration and V8 swap
                  24 Hours of Lemons e30 build
                  • Ahheck01
                    • Aug 2004
                    • 185
                    Here's the other closeup I've got:
                    • JGood
                      • Jan 2004
                      • 7959
                      Yup. Pic two:
                      That sucks. Looks like you have an m30 jammed in there ;)
                      Do you have prior bodywork experience?
                      • Ahheck01
                        • Aug 2004
                        • 185
                        Last pic for now:
                        • Ahheck01
                          • Aug 2004
                          • 185
                          Lots of research, none put in to practice however. Willing to learn.
                          -Evan
                          • Teaguer
                            • Sep 2004
                            • 6167
                            Do I have to be the one to say it ?
                            Nice r3v !!11!!11!!
                            • Ahheck01
                              • Aug 2004
                              • 185
                              Nice r3v !!11!!11!!
                              lol. :buttrock
