I need some pictures...
  • psloan
    • 9815
    Originally posted by Teaguer
    Actually you had 255/40's back there .
    Yes neither of those guys is running anywhere near the width that could fit back there .
    What are your plans for the car in the sig? Sexy wheels (on the front, anyways)
    • Teaguer
      • Sep 2004
      • 6167
      2.5 Eta in the works .
      What you don't like my awesome rear wheels ? :D
      • psloan
        • 9815
        2.5 eta?? Not a 2.7i?
        • Jordan
          • 12916
          255/40's did not fit though. Rubbed, mostly due to the shape of the Kumho 712 tire though. The 245/35R18 Toyo T1R's fit fine.
          https://mtechniqueabs.com/
          • PiercedE30
            • Apr 2005
            • 4220
            Jordan, How much rolling/pulling did you have to do to fit those 245's?
            My 2.9L Build!
            • GarrettM
              • Jun 2007
              • 674
              What kind of flares are on that white car?
              • Slyder
                • 348
                Originally posted by nando
                I think it looks better on the white car because the rear flares are a bit wider than the front. On the black car they are the same width, but because the front arches are higher it has the effect of making the fronts look wider and throws off the proportions. Also, his wheels/tires are too small :p
                that white car is one of the best MtechII cars I've ever seen though!
                I just saw this post, so sorry for the late reply.
                The flares are NOT the same width as stock. They are 1" wider on all corners.
                As for the execution of the flares, I am in no way satisfied with the way they were done. I paid a shop to do the modifications and it wasn't until much later when I fitted my new wheels that I realized just how poorly done they were.
                In the next month or two, once the engine is fully up and running and broken in/tuned, I will be cutting the flares completely off the car and starting them again from scratch. The new ones will be much larger, and more aggressive, and the rear track will be widened an additional 30mm from where it sits now. Also, the new flares are planned to be done in sheet metal, however I won't completely shun fiberglass if it ends up being the better choice. If I do go that route, they will be reinforced with CF and Kevlar. The result should be unlike anything anyone's seen done to an e30 to date. I'll have the bodywork donw by BimmerFest...paint depends on a lot of variables...but the whole car is getting re-sprayed.
                Also, the wheels/tires shown in the last photo are 18x8.5 fronts on 245s, and the rears are 19x9.5s sitting on 255s. I've had up to 275s fit back there.
                - Jason
                  • 34844
                  I meant that the front and rears are approximately the same width, not that they are the same as stock. the other car has the rears larger than the fronts, which makes it look more proportioned given the lower rear arches.
                  I know about getting screwed by a bodyshop - hope it works out.
                  • Slyder
                    • 348
                    Thanks for the clarification :)
                    FWIW...anyone in the El Paso area, STAY AWAY from AutoBody Creations
                    - Jason
                    • golde30
                      • 11464
                      ready before Bfest eh Jason...heard it before, dont believe it.;)
                      PS: 18"/19" staggered eh? werent you just giving me a hard time about 17/18 staggered???
                      IG: @Baye30
                      • Slyder
                        • 348
                        lol...so you caught my typo :P. 18x8.5 fronts and 18x9.5 rears ;) happy?
                        - Jason
