What is required for E30 S38 swap?
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    #76
    Originally posted by LINUS
    If you mean me, I was outlining cost, not apple-apple comparisons. 2 different worlds.
    I personally think guys who **need** a S38 swap are the same kind of guys who run 37"+ tires on asphalt queen trucks. It's cool, but whatever. Glad someone **needs** those used S38's. Personal opinion, I guess.
    Amen brotha.... Preach on.
      • 34847
      #77
      so if cost is the only metric, we should all be building M10s right?
      an M52 is like an M20 on steriods. an S38 is an entirely different beast altogether.. trying to compare them on a cost basis is just retarded.
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        #78
        MY comparison
        Based on Logic, Not cost...
        In MY reality, coming from a guy that runs a Honda specialist, Nobody is swapping a b17a. Everyone and their mothers go for B16 - B18. The B17 is the Honda bastard child in the US. Can it be done? Yeah. Is there any other question? WHY? Why would someone go thru the rigors to source parts, peices, components for an uncommon, off the beaten path engine swap? It's like the choice between a SBC, or a BOP small block. Very similar, but use different parts. These are cars we're talking about, why make a choice that will leave your car on jackstands waiting for a euro part that costs 2.5 times the cost of it's contemporary counterpart? Instead of having the ability to drive down the street to pick up a replacment?
        Why would you stuff a bastard in your engine bay?
        • euroshark
          • Apr 2006
          • 3491
          #79
          Aren't the two blocks fairly identical as far as mounting?
          Same block as the M90 motors used in the old old Euro E23s and E24s... The block is coded M49. It's the same exact block, crank, and rods as used in the M88/3 and the M90 (the street version of the M88/3 if you will, it had the single cam head), so mounting the S38 should be the same as mounting an early M30 (or M90) except that the headers might cause issues on the passenger side mounting bracket.
          If you want more info on the M49 block or the M90, M88/3, S38 family buy the "6 Series Enthusiasts Companion" by Jeremy Walton, it's got the full history of these engines.
          • James Crivellone
            Head Janitor
            • 6305
            #80
            I will one day run an S38 in my car, and I could careless if I spent 20 grand on the damn thing!
            Newer motors are boring, the old high strung to the motherfucking max motors are what I like.
            • FredK
              • 14764
              #81
              I feel the S54 isn't really boring. I feel it's high strung to the motherfucking max as well.
              • LINUS
                • 2422
                #82
                Yee haw... you sure showed me.
                Look, I'm just thinking that a S50B30/32 is a hell of a motor, or a S54 - sure you can make a arguement for S38s, but their time as a Hi Po motor are dwindling, otherwise Motorsports division would be using them in 2007.
                If you want to stick to the whole "period correct" thing, then sure - that's a semi-passable reason, just be prepared for the cost.
                If you have the initial cash to do one, and the reserve cash to rebuild one than you are a thick wallet. Good on you, seriously.
                You keep focusing on that M52, why? It was a passing reference.
                I only used that as an example of cheap HP, nothing more. If you can't see that, then you are 'just retarded'. If we need to cut to the chase & flop our dicks on the table & measure who's bigger that's fine. You might win, I don't think I've got a big gun, just a sensible brain.
                Opinions on S38s are like assholes, we all got one. I would choose a S50 varient with a snail over a S38 myself, but whatever.
                It's not how you handle the good times, but the faith you keep in the bad that defines you.
                • BenM
                  • 2184
                  #83
                  Why not an S38 with a snail?:p
                  And if you haven't heard of this car before, I present to you all, Lucifer's Hammer. Can you say Turbo'd 4.0 S38B35 that puts down 700HP at 14lbs. of boost?
                  Just go over to mye28 and search for "Lucifer's Hammer". That car just rocks my fucking socks off.
                  Originally posted by BillBrasky
                  E36's are the Stephen Baldwin of the 3 series family. They barely hold everything together and they only sold a lot because of the popularity of their older sibling.
                  1991 318i Alpine II - S50/5-lug swapped - track car
                  1989 325i Cirrusblau - Daily
                  1970 2500 - Malaga over Grey Cloth
                  2012 F350 6.7PSD
                  • BenM
                    • 2184
                    #84
                    Ah, I just found some pictures of this beast.
                    2012 F350 6.7PSD
                    • smonkbmw
                      Professor
                      • Jun 2006
                      • 4549
                      #85
                      yes i can say that. but were not talking about built motors here. if you keep searching theres some crazy norweigans (sp?) with a vertical mounted TT s38 in a tube chassis e36 running 1200hp....woo hoo.
                      im curious if the OP is even looking at this thread anymore.
                      • ILoveMPower
                        • 607
                        #86
                        I'm just curious how many S38 cars you've owned/driven? Seems a lot of your comments are just you talking out your ass because you can't afford an S38. If you don't like my ideas for project, why do you post?
                        I could stuff an S50 in an e30, but then it would just be another e30 with an s50. Personally, I'd rather live up to the nickname of "The Ultimate Driving Machine," and to me the S38 is the ultimate straight six filled to the brim with motorsport soul. Sure it could be more efficient, sure it could be faster, better gas mileage... but there is not much else that could be any more raw and enjoyable.
                        Just my opinion...
                        1990 Islandgrun 535iM Sedan
                        Euro lights + trim | Eibach/Bilstein | BBS RC090 17x8 | EAT Chip | Port + Polish | IE 284 Cam | Built valvetrain
                        • redbull 325is
                          • 7472
                          #87
                          So you are trying to re engineer the most expensive, hard to maintain motor BMW from the 80s with a car that was designed late 1970 technology to achieve some kind of bavarian nirvana?
                          gl with that.
                          Julien
                          Build Threads:
                          • FredK
                            • 14764
                            #88
                            Plenty of people can afford an S38. Not many people can afford to rebuild it.
                            • redbull 325is
                              • 7472
                              #89
                              fuck that.. here is your real responce:
                              he just wanted ppl to say, DUDE U ARE SO SICK NASTY, CAN I TOUCH UR PP?
                              Build Threads:
                              • LINUS
                                • 2422
                                #90
                                I drove 2 M5's. One was an Ex's parents car, and I probably spent 10 hours real time in it. Her dad was a sucessful lawyer, and I remember one time when he was livid over what a top end service job cost. I can say it sure seemed like fun to carve off some weight & throw the motor in a lighter shell, just that there might be more cost effective ways to get there now.
                                Not that I need to prove anything, but I also racked up shy of 20K on my S14before pulling it. So I had 2/3 of a S38 for a while, and did all my own service work. And paid for the parts.
                                In its' day, sure - an S38 was the billybadass motor - but most of us here don't have the driving talent to need a S38, much less the Euro S50's or even comparable HP modded US motors like a S54.
                                If you got a hard-on for a S38 E30 - great. It's just a common crackpipe question, and 99.999999% of the people who ask it here don't persue it once they seriously pencil out the budget. Your 1st post didn't make it clear you were a contender, so settle down.
                                And yes, I talk out my ass plenty of the time. But I have swapped a 24v myself, so I think I can talk a little here. I might only have a U.S. OBD1 S52, but it's enough to get you in trouble, and I did a ton of self research before I started. All work from pulling my S14 to doing my new motor was all me.
                                If you're East Coast, call Vlad's guys - they could give you all the info you need.
                                You can argue all you like, but you come on here & asked a pretty basic question that any serious person looking to do the swap would more than likely just contact someone who had already done it rather than ask the masses.
                                Anything else?
                                Here's why I think I can talk some:
                                May not be your flavor, but it show I'm not a hater running around in a clapped out M10 car.
