Need Help with Chip!
  • Quik325ix
    • Mar 2005
    • 381
    I just got my ecu all taken apart and ready to take the old chip out and the fucker is soldered to the board. How do i get the old chip out and put the new one back in?? Please help...car not driveable at the moment!
  • JJe30
    • 2044
    Get a soldering iron and heat up the contact points to remove and solder back in.
    • bimmer8604
      • 3017
      i dont think ive ever done a chip in an e30 where its soldered in...ohwell.
      guess you could do what the guy up above said.
      1988 M3, 97 840, 99 XJ
      DILLIGAF
      • Quik325ix
        • Mar 2005
        • 381
        Alright i cannot get this thing. Does anyone have any other ideas? I have tried heating up the contact points, but it doesnt seem to do any good. Do you all know someone that i could take the thing to? I dont think a mechanic but maybe an electrician or something? Or would any of you be able to put this chip in there for me? Ill ship it to you.
        • george graves
          • 20003
          You don't know what you are doing - STOP right now.
          I would suggest you take it to a TV/VCR repair shop (hard to find now-a-day)
          Tell them what you want to do - if you insist doing it your self get a "solder sucker" from radio shack, and some solder wick. Heat the solder, and suck up the solder. Finish with the solder wick if need be.
          If you don't know what you are doing, you'll more then likely ruin the PCB(the circuit board) in the process by "lifting" the pads (separating the traces off the board)
          Sure you are replacing the right chip?
          Originally posted by Matt-B
          • Quik325ix
            • Mar 2005
            • 381
            I am pretty sure it is the right chip. I didnt really persue the soldering method because i am pretty sure i would screw it up. But Thanks for the advice and I will definately see if i can find a TV/VCR place. Much appreciated!
            • E30 Cabrio
              • Oct 2006
              • 1954
              I don't think you're pulling the right chip.
              It should pop out using clips.
              I don't know of any E30 ECU's that used soldered chips.
              1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
              Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
              Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
              • Quik325ix
                • Mar 2005
                • 381
                ok i was wondering about that. Wok help orient me if you would. When looking at the ECU there are 2 chips that are going to be in the bottom right hand quadrant of the ECU. The one closest to the bottom is the one that i was going after. There is another one that is more elevated than the others and has a black plastic housing over it. Is that the one i should be after?
                • Quik325ix
                  • Mar 2005
                  • 381
                  ok looks like i was going after the wrong chip. now how do i get that bastard off?
                  • gobuffs
                    • Dec 2004
                    • 513
                    My 84 325e had a chip that you could not pop out.
                      • 34847
                      maybe, but he has a 153 ecu at the very least, and it's definitely not soldered to the board.
                      • Quik325ix
                        • Mar 2005
                        • 381
                        yea mine is actually a 380....which i have never freakin heard of.
                        • Pinepig
                          • Sep 2007
                          • 1811
                          Picture are worth 1 bazillion words in this case.
                            • 34847
                            there's lots Motronic 1.3 ECUs - 173, 280, 524, 525, etc. etc.
                            • steinbachphoto
                              • Aug 2007
                              • 914
                              post pics!
                              http://www.steinbachphoto.ca
