91 318is or 84/85
  • Ara
    • Jan 2006
    • 365
    91 318is or 84/85
    so my buddy wants to club race, he is wondering which is a better buy...the 91s or 84/85?
    pros / cons
    i know the weight and power/tq ......anything else ?
    • 34839
    you're going to have to replace EVERYTHING on the 84/85. And I don't just mean wear items - there are things specific to early cars that aren't compatible with the rest of the E30 aftermarket.
    I'd just go with the 91.
    • Ara
      • Jan 2006
      • 365
      im talking about same milege...sayyy both at 100k
        • 34839
        mileage doesn't matter so much. the 84/85 has smaller struts, drum brakes and other stuff that you don't want. you can replace all of it if you want but it's easier to start with car that has that stuff already.
        • sumyungguy
          • Feb 2007
          • 1313
          Hands down the 91... Newer technology motor, rear disk, sport seats, extremely well balanced.
          Unless your going to build a full race car, rip apart a 84.
          • cwbaader
            • Oct 2005
            • 29
            There seems to be gross misinformation on the 84-85 cars. All suspension pieces are the same as the later 325 cars. That means any strut inserts, shocks, brake rotors, diff, etc. are interchangeable. Any aftermarket suspension you want will bolt on. The older "e" cars run ITA in SCCA, and MP in BMWCCA. They also run GTS2 in NASA, but the newer 91 car runs ITS and is not competitive, Period.
            IF you have a good straight body the earlier makes a very competitive race car. Chuck
            • Dirtsquirt
              • Nov 2004
              • 686
              He's talking 318i, me thinks.
              They had drum brakes in the rear and smaller struts up front. I'm not sure about it having ABS either.
              -Dan
              • asubimmer
                • 6482
                you are misinformed grasshopper
                • asubimmer
                  • 6482
                  -Dan
                  correct, they don't have abs either
                  • Ara
                    • Jan 2006
                    • 365
                    under page 23...says the 318i cars ARE in ITA.
                    • Dirtsquirt
                      • Nov 2004
                      • 686
                      Originally posted by Ara
                      http://scca.org/documents/Club%20Rul...vedTouring.pdf
                      That doesn't mean shit. He and I were pointing out that the 84/85 318i's are far behind the "raceability" of ANY E30 325. If you're going to get a 318i then get a '91 iS
                      -Dan
                      • Brinkley
                        • 379
                        if the price is the same get the 91 man get the 91 even if its more expensive man
                        get the 91
                        I don't think your mom appreciates the value of those modifications
                          • 37833
                          Grover Beach, California
                          BimmerHeads.com
                          • Bill-B
                            • Apr 2007
                            • 1242
                            trust me, the 91 is where its at
                            Originally posted by NavyE30
                            I saw Vlad was posting and got excited. Then I saw there weren't any boobs and was sad.
                            • Jean
                              • 18228
                              8v 4cyl, drum brakes, thinner front struts and solid non vented front rotors FTW! :p
                              What's the plan though, will you be taking everything and replacing it ? If so, then I vote an early car, less stuff, less weight.
