Get up and go..
  • mtechnik
    • 6156
    My bad yes of course.
    • Ablice
      • Sep 2006
      • 261
      Honda Fits have a little red [image of a thermometer] icon with a "H" for hot, and bluish [image of a thermometer] icon with a "C" for cold.
      Lame. Cheap kaws though, and with the declining quality and throw-away purpose these days (combined with *yawn* slushboxes and people who don't understand what it means until the engine doesn't run anymore) it's expected.
      For the iS, just started up and went. But the 325i I let it run its little early snoozyness (tired old neglected engine) then go.
      :mrgreen:
      Like game music? >clicky<
      • fretburnr
        • Jan 2005
        • 1496
        unlock it, cock it, rock it.
        keep it under 3500k or so until warm.
        Jay
        • bimmer8604
          • 3017
          start it, wait for rpms to drop, then go. my car doesnt like to drive when its cold, so i have to baby it. but i have a nice easy winding side street to take it easy to get things warmed up before goin wot. and living in Tulsa, its either WOT or stopped.
          1988 M3, 97 840, 99 XJ
          DILLIGAF
          • M5wanaB
            • Aug 2007
            • 405
            From what Ive heard BMW does not recommend that you let the car warm up. You should start it and begin driving. This helps to warm the engine up more rapidly and helps expel the moisture that has collected in the combustion chambers and intake. You should not begin driving the engine hard until it reaches operating temperature. You should also not drive the car hard until the Trans and Differential oil has had time to reach operating temperature as well. I use to let mine warm up till I read this and had many people confirm it on Bimmerforums, just a heads up. It may save you a gallon of gas a year, lol.
            1991 325iC w/ 75k Original Miles, Brillantrot, 5-speed, 16" BBS RX's, Black Leather Sport Heated Seats, LSD, and Diving Boards for life!!!:D
            • sticksdaman
              • Apr 2005
              • 2987
              yea in the manual they say to start driving right away keeping it under 3k ...so thats what i do
              the car actually runs better when its cold outside (atleast to me it does) probably has something to do with the dense cold air and fuel atomization and yadda yadda
              Originally posted by ebelements
              Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
              • Jand3rson
                • 37587
                Originally posted by NitroRustlerDriver
                I believe it used to be thought that letting an engine idle to warm up before driving it was the correct thing to do, but in recent years, mechanics have found driving the car is much better then letting it sit. Something about the varying RPMS is better then staying at one constant RPM.
                Now, that's not to say you should redline the engine when cold, but driving is fine.
                I usually just give the engine a bit of time to get oil circulating everywhere and then take off. That way I don't put stress on anything that isn't lubricated.
                This what I've always done. And in fact, if you read the owner's manual, it actually tells you just to start the car and go, never to let it sit and idle.
                • AlarmedBread
                  • Sep 2006
                  • 1510
                  I park in 1st, when I go to start it, put my foot to the floor and let the starter bump it while in gear, then when it comes to life shift after fishtailing out of my parking spot bumping off the limiter in every gear. :up:
                  • golde30
                    • 11464
                    +1.
                    IG: @Baye30
                    • euroshark
                      • Apr 2006
                      • 3491
                      I let my 6er warm up for about 2 minutes, she just doesn't like to go when it's cold out... I can't wait until the new head is ready to go on... Along with the IE headers... No mo EGR system (damn federalization...) :pimp:
                      I give the Alfa about 60 seconds, max. Definitely don't run either engine over 3k before they are nice and warm... I'm a bit paranoid.
                      • mtechnik
                        • 6156
                        Did you import your Alfa Romeo or were they sold in the States during the
                        90s?
                        • Spiff325iS
                          • Jun 2004
                          • 1263
                          Awesome, I feel much more comfortable now. Actually this thread turned out pretty amazing...lot of good info..just thought i would throw that out there.
                          The Red Dragon V.5 1991 318iS / 2013 F800GT
                          "You gotta fix the nut behind the wheel before you fix the bolts on the car"
                          • ibavarian
                            • 94
                            Start it, make sure oil pressure light goes off, wait another 10 seconds for oil to circulate..drive off. Wait till its at operating temp before I decide to push it past 4K.
                            "Full throttle till you see god, then brake hard"
                            90' 325i f0 door
                            06 Kawi ZX6R
                            • dvs909
                              • Sep 2006
                              • 1149
                              start it, walk around it to see whats fallen off or what lights have burned out since last time, get in and drive a couple miles, then rev limiter in every gear.
                              ________
                              Honda Phantom specifications
                              • whiltebeitel
                                • Apr 2007
                                • 2098
                                Originally posted by golde30
                                +1.
                                +2
                                '89 325i track sloot
                                '01 530i daily
                                -Enginerd
