When Replacing Front Wheel Bearings...
  • Ben Carufel
    • Jun 2004
    • 5248
    What all do I need to replace from the following diagram (besides #1, the bearing/hub assembly)...
  • Axxe
    • Aug 2004
    • 3355
    # Invisible?
    Bearing/hub assy, axle nut, dust cap.
    Keep it slideways!!
    • Jordan
      • 12916
      Just the big nut Ben. Unless you are a monster you should be able to reuse the dust cap.
      https://mtechniqueabs.com/
      • Axxe
        • Aug 2004
        • 3355
        Dust cap is what, $2? I rather buy new ones just in case.
        Keep it slideways!!
        • rs4pro3
          • 5808
          ya 1,3,4
          85 325e 2.7 ITB'd stroker
          • FredK
            • 14763
            Naw, he's from CA. You could probably pry the dust cap out with a jeweler's screwdriver. No rust. I removed a brake disc setscrew from an 30K mile M3 hub, and it was on a tad past finger tight. I nearly wept.
            • Ben Carufel
              • Jun 2004
              • 5248
              I'm going to replace all that crap, just 'cause I'm anal about this car.
              • Jon325i
                • 6934
                If its been a CA car most/all its life, just check the dust cap and nut for rust. If there's just a little surface rust, brush it off with a wire brush and coat it with some WD40 or something similar. That's all it should really need. If you have to replace the nut or dust cap, don't worry.....those are R3V cheap.
                Jon
                Rides...
                1991 325i - sold :(
                2004 2WD Frontier King Cab
                RIP #17 Jules Bianchi
                • Axxe
                  • Aug 2004
                  • 3355
                  Track guy mentality = replace EVERYTHING.
                  Keep it slideways!!
                  • ptownTSI
                    • Jun 2005
                    • 1265
                    the dust cap serves no purpose other than keeping dust out, if its like my e30 they came out super easy, so i just reused them. it might be cheap to get new ones but its still a waste of money if you don't need it.
