Need opinions on possible E30 buy
  • CincinnatiKid
    • Nov 2007
    • 716
    Alright guys I need some opinions on this E30 I'm looking at. It's an '87 325is with about 88K on it, odometer quit working and carfax has 80K at last date registered. Owner says he has replaced timing belt and some other parts on the motor and claims the only thing wrong with it is the clutch release bearing is going out. The body is in good shape, no rust cause it was in florida for most of its life, but the paint on the hood has oxidized pretty well, and the passanger taillight has a crack in it. Interior is ok, not great, driver's seat is pretty well work with rips. I offered him 1800 for it you guys think this is a good deal or is it too high of a price? TIA.
    1990 S50 goodness.
  • ethree
    • Aug 2007
    • 1216
    I'm always suspicious of faulty odometers that being said do drivers seats generally wear heavily in 88k miles of use? does he have records or just says the t-belt was done recently?
    • Jean
      • 18228
      I am going to have to say one thing. Don't buy a car without records unless you plan on fixing things down the road to make it right. /end.
      tail light is a cheap fix, they are about 30-50 for a good used light.
      no rust is good, paint might buff out if it's single stage w/o clear coat.
      How does it drive ? When was the last time cooling system was flushed ? Brakes ? Suspension ? Passed smog ?
      Other than that , not a bad price for an 87 325is.
      • ncgneto
        • Oct 2007
        • 170
        Florida car? Check for rust on the sunroof. Mine was all the way rusted when i took off the headliner. E30's are easy to roll back mileage. Carfax it
        86 BMW 325E - For Sale ~ $1,200
        90 Mazda RX-7 - Project car/Project car
        01 Audi A4 - Show/Date car/Project car
        • CincinnatiKid
          • Nov 2007
          • 716
          Last carfax entry was a few years ago and it says 88K for odometer, it's been sitting for a while too
          1990 S50 goodness.
          • DarkWing6
            • Apr 2004
            • 7144
            even if the odo is wrong or has been rolled, $1800 for a clean 87 325is is a good price. have it checked out before buying, but i'd probably go for it.
            • CincinnatiKid
              • Nov 2007
              • 716
              How hard is installing a new clutch kit on an E30, I've done it on Jeeps before.
              1990 S50 goodness.
              • redbull 325is
                • 7472
                not too hard, i'd say a good weekend's work.
                Build Threads:
                • markseven
                  • Sep 2006
                  • 5327
                  It may be worth it to you in the long run to have a reputable independent shop inspect the car.
                  I Timothy 2:1-2
                  • JK_E30
                    • Jan 2007
                    • 545
                    Unless you have access to a lift, from experience I would suggest pulling engine and tranny to do the new clutch. Doesnt take too much longer and is a hell of a lot easier to get at the bolts on the bell housing.
                    Like stated above, good weekends work.
                    Good luck.
                    M50B25tu
                    • einstein57
                      • Jun 2007
                      • 10780
                      check all the rubber eg weather seals, suspension bushings, hoses, cab, etc. Can add up quickly and take a full weekend to replace.
                      www.gecoils.com
