Wheel weight
  • ///Mtechnik88
    • Mar 2004
    • 129
    Wheel weight
    I am plotting a set of 16" or 17" wheels (probably 16's though) and wanted opinion's on wheel weight, and if there is a "magical" number not to exceed. When does too much weight start to become a problem performance/ handling-wise? The wheels I am looking at range from 17-24lbs/ wheel. Any recommendations based on knowledge, and or personal experience would be great. Thanks!
    '98 BMW 318ti M-Sport California
    '87 Ford Sierra (Merkur) XR4ti (Track)
    '99 DINAN/Hartge 3 (retired)
    '88 325iS Eurosport (retired)
    '85 318i (retired)
  • Digitalwave
    is a poseur
    • 6297
    Probably over 18 lbs you are going to start feeling it. 24lbs is rediculous.
    RISING EDGE
    • Low Level E30
      • 1646
      See if you can get your hands on some Kosei K-1s in 16", if you're worried about weight.
      Rota also makes some good-looking wheels that'll work, in higher offset (40mm) - you'll need spacers.
      There are other options, but you're gonna be lookin' at $$, as always. Plenty of wheelmakers cater to the Japanese imports, but their wheels can be chintzy. Generally, you get what you pay for...
      You'll feel 24lbs wheels, for sure. 16" E36 Sport Package wheels (7" wide) are 19lbs - that's probably about as heavy as you'd want to go, on an E30, certainly not much more.
      • Mystikal
        Wheel Fitment Expert
        • 9602
        Generally, less than a pound per inch of diameter is considered light. For example, a 16" wheel that weighs 15.5lbs is considered lightweight.
        • bimmerphile
          • 3495
          www.wheelweights.net
          good resource.
          • M42Technik
            • 9781
            Kosei K-1's don't come in 16" without spacers, unless I'm mistaken. Rota you will need hubcentric spacers as the centerbore is different (just like Mini's). Of course you get what you pay for in the end, so save up big money for the right wheel.
            Reminiscing...
              • 34839
              they make Kosei K-1 in 16x7.5" with a 32mm offset.. that's a little high for a RWD car, but it might work. look under the 325ix.
              • cheades
                • 632
                A 32mm offset should actually fit, I have just barely enough room to fit my 17x8 K1's that are 35mm.
                • M42Technik
                  • 9781
                  Really? Damn. Post a picture of that...
                  Too bad Kosei K-1's have no outer lip...
                  Reminiscing...
