BMWs (Finally) Get Brembo Brakes OEM...
  • uofom3
    • Jan 2004
    • 5392
    #46
    I'd rather see AP racing make a factory/OEM kit. Brembo makes good stuff, but it's just so played out and there is better stuff out there.
    PNW Crew
    90 m3
    06 m5
      • 34839
      #47
      I think you guys are having a hard time with the relationship between mass and the amount of power required to move it. good job matt on your explanation!
      • FredK
        • 14761
        #48
        no, it's an issue of semantics and what is being held constant. Matt is holding power constant. Emre is not. That is why they aren't seeing eye to eye.
          • 34839
          #49
          yes, he's not holding it constant because he's not relating it to the mass that's being moved, and why it's harder on the brakes (because of the power, not the mass).
          I'm on your side here, damnit! :p
          • brandondan1
            • 1091
            #50
            Exactly. Neither of us were wrong. We were just debating about different factors.
            91 318is
            • matt
              • 3732
              #51
              Originally posted by brandondan1
              However, if the heavier car had a engine that allowed it to accelerate the same as the lighter car, the lighter car would still have a braking advantage, no? Are you saying that if you had a choice between at 2700lb 135 and 3000lb with a few more horsies, you would pick the latter? Basically, I think Erme's original point was that if you want a heavier car to be COMPETITIVE with a lighter one, it's going to require more stress on a lot of things, including the brakes.
              It would be at a braking and cornering advantage. Lighter is better, pretty much all the time.
              Thanks.
              • Emre
                • Sep 2007
                • 1228
                #52
                The bottom line is:
                (1) The E92 M3 has a curb weight of ~3700 lbs. To put things in perspective, my E30 track car weighs ~1100 lbs. less than this behemoth; my 400 hp Evo VIII weighs ~500 lbs. less and has bigger/better Brembo brakes.
                (2) All the reviews from the E92 M3 press launch have stated that the brakes went away after just 2-3 laps, even though they were fitted with race pads. Reviewers from evo magazine experienced brake fade on the street.
                That's the whole point. This car has inadequate brakes. Period. Brembo brakes will be a welcome upgrade.
                Emre
                1987 Mercedes 190E 2.3-16: Vintage Racer
                2010 BMW (E90) 335xi sedan: Grocery Getter
                • CleanAzzE30z
                  • Jan 2004
                  • 11794
                  #53
                  Originally posted by Ben Carufel
                  What does this mean for BMW-specific BBK manufacturers?
                  Also, now we can stop calling them "Porsche Big Red Calipers".
                  thanks god, and for fucks sake its about time. How long has the brake issue been plaguing tracked BMWs???
                  Mariano
                  • Massive Lee
                    • Sep 2006
                    • 6785
                    #54
                    I wouldn't trust either Brembo's F40 calipers on a track car. Those are street calipers. They are cheap but have great visual impact. I think that's where it ends. Guys with Mitsubishi Evos and Subaru STi find them weak on a racetrack. Not to mention that the rubber dust boots are easy to melt, and that the aluminum calipers transmit heat to the brake fluid at lightning speed.
                    I'd rather go with a race AP caliper, than what Brembo offers. Commonly. Brembo does have great products for racers, but not in the Gran Turismo range. Multiply the price of calipers by at leat two.
                    massivebrakes.com
                    • matt
                      • 3732
                      #55
                      Evos and STIs both have brake cooling issues because of their front driveshafts... there's no room for really effective ducts.
                      And because of their power.
                      Not because of their weight.
                      :mrgreen:
                      • Emre
                        • Sep 2007
                        • 1228
                        #56
                        Despite that, Evo brakes are considerably better than the OEM E46 M3 brakes...a car that's heavier and more powerful in stock form. The E92 M3 is even heavier and more powerful. If there ever was a factory car that cried out for better brakes, it's the M3.
                        Emre
                        • Emre
                          • Sep 2007
                          • 1228
                          #57
                          The problem is simply cooling, which is totally inadequate. No one complains about the calipers themselves.
                          My dust boots were still fine after 4 years and 55K miles of street and moderately heavy track use. I overheated my calipers to the point where the red paint turned brown...yet the dust boots did not melt. BEesides, the rubber boots can always be replaced should the need arise.
                          I agree that there are better calipers on the market than Brembo F40's. But the Brembos are hardly garbage. And they're certainly much better than OEM BMW brakes...even those on M Cars.
                          Emre
