engine oil light
  • mark///m3
    • Oct 2007
    • 287
    engine oil light
    so my engine oil light comes on when i hit the brakes(the overhead one) any ideas what would cause this. if you look the brake light bulbs on the overhead flashes for a millisecond andthen the oil one stays on while the pedal is pressed
    ___________________
    Mark
  • mark///m3
    • Oct 2007
    • 287
    bump
    ___________________
    Mark
    • Charlie
      kid tested, administrator approved
      • 6686
      Stupid question, you check your oil level?
      -Charlie
      Swing wild, brake later, don't apologize.
      '89 324d, '76 02, '98 318ti, '03 Z4, '07 MCS, '07 F800s - Bonafide BMW elitist prick.
      FYYFF
      • uofom3
        • Jan 2004
        • 5392
        exactly what I was going to say.
        also possibly a loose connection at the sensor?
        PNW Crew
        90 m3
        06 m5
        • franco90
          • 3185
          try the oil pressure sensor check if you have oil in the engine
          I've always been proud of being a Marine.
          I won't hesitate to defend the Corps
          "Supersquad"
          ‎"Prostitutes are a sub-category of Amusement Parks"-
            • 34844
            the overhead sensor is for oil level, not pressure.
            • franco90
              • 3185
              Nando you r right I didn't read the original post
              "Supersquad"
              • mark///m3
                • Oct 2007
                • 287
                there is oil in the car
                ___________________
                Mark
                • bimmer8604
                  • 3017
                  sure there is oil in the car. but check the level.
                  or check for a loose connection.
                  1988 M3, 97 840, 99 XJ
                  DILLIGAF
                  • mark///m3
                    • Oct 2007
                    • 287
                    it is when i hit the brakes and the level is right on the money
                    ___________________
                    Mark
