Questions to those with a 318is : what kinda gas ?
  • royalflush313
    • Mar 2004
    • 2070
    So when I got it I filled up with a 89, but then afterwards I noticed that BMW receommends premium (91?) on the 318is.
    Do all of you actually put in premium or higher in the car, or just use regular 87 or 89 ?
    With the gas prices now, I'd probably save $5 each time I fill with a 87, but if there's a reason why only the 318is needs premium, i wouldnt cheap out on gas.
    8)
    ~ Go Canucks Go! ~
  • Rob
    • 8166
    My car had detonation on the dyno with 87 octane, so run at least 89 to be on the safe side. If you have a chip, definately run premium
    BEERTECH
    • bimmerphile
      • 3495
      Dude, B M W
      don't skimp on gas
      • 318daily
        • 507
        mine was chipped, so i used 91.
        i would only put 87 in a rental car.
        • Rob
          • 8166
          Originally posted by bimmerphile
          Dude, B M W
          don't skimp on gas
          LOL
          BEERTECH
          • kencopperwheat
            King of Kegstands
            • 14396
            The octane numbers in europe are different than in the USA. In europe they use RON and in the USA we use PON. 91 RON = 87 PON. Thus, the manual states to not use anything lower than 87 octane here in the USA.
            Originally posted by Gruelius
            • e30Matt
              • 5077
              I think 87 is the lowest you can get... but I run 93 without a doubt
                • 34847
                91.. the M42 has a fairly high compression ratio (10.1:1 or something). even stock you'll get detonation if you run cheap gas. contrast that with the M20's 8.8:1 ratio...
                • SykoBMW
                  • 1065
                  I guess my dads M3 is supposed to run on 87 then too? :roll: I know they're different, but they do call for premium.
                  • Rob
                    • 8166
                    your dads car would probably be fine on 87.....modern ECUs have knock sensors that pull timing when knock is detected, preventing engine damage. Our cars, not so much.
                    BEERTECH
                    • ///M42 sport
                      • 3952
                      I've run 89 a couple of times due to the high prices and haven't noticed any negative effects.
                      ________
                      Fix ps3
                      • Streetspec_iS
                        • 1622
                        i run a 98RON. which is about equivalent to a 91 in the US books. run a bit of octane bost every now and then. cleans the injectors out a bit if nothing else.
                        sigpicM42 Brigade ... Throwing craze in the 318
                        • BS87
                          • 1606
                          I run 89, minimum, and only because i can't find a gas station withing 50 miles of me that sells 91
                          • e9nine
                            • 1890
                            93 or 91 religiously
                            • LikeCDoos
                              • Jan 2004
                              • 2522
                              91 for me with my JC chip
