crank window conversion
    • 34839
    #46
    Originally posted by delatlanta1281
    Ok cool. What have you done since those pics?
    he's parted it out, that's what. ;)
    • Turf1600
      • 9815
      #47
      Originally posted by atomic
      You can save 135lbs of weight if you would stay out of your slow eta and not drive it at all.
      It would weigh even less if he parted it out and sent it to the crusher.
      • atomic
        • Jun 2007
        • 5691
        #48
        I think his thirst for MORE POWER and his admission to speeding (although a bit exaggerated ), that he is more likely to take care of that at one time with him in it.
        • Disaster Inc
          • Oct 2007
          • 429
          #49
          I think he should build a complete 4 door eta shell from carbon fiber since he makes his own. http://bimmerfest.com/forums/showthread.php?t=268367
          • James Crivellone
            Head Janitor
            • 6303
            #50
            The power window circuit run on one damn wire, and ground.. I fail to see the benefit here, but whatever.
              • 34839
              #51
              because the 10lb weight savings it will make him faster, duh :p
              it's funny because I've skooled many an E30 with gutted interiors, no radios and all sound deadening removed with my heavy 4 door full interior jack & spare in the trunk POS. but what do I know? :)
              • DSP74
                • Nov 2007
                • 1121
                #52
                Whether or not this guy needs to be flamed or not has no bearing on the fact that 10lbs is a worthwhile drop in weight. And you can do so without "gutting" the car.
                It may not even be worth 10lbs. Who knows.....But every little bit helps.
                Removing it to remove electrical items is dumb though......It's a car not a bicycle.
                88 325is
                • Turf1600
                  • 9815
                  #53
                  I highly doubt it's even 10 lbs in weight savings. Besides, it has an eta in it and a retard driving it.
                  • DSP74
                    • Nov 2007
                    • 1121
                    #54
                    OK fair enough......
                    Since this topic has taken a major turn for the worse I'm probably wasting my time but........
                    Anyone actually know the weight differences in crank vs power windows?
                    88 325is
                    • Farbin Kaiber
                      Lil' Puppet
                      • 29502
                      #55
                      Give or take, but, It's gotta be at least a few parsecs.
                      • z31maniac
                        • 17566
                        #56
                        So he's gone from an M50 to M60 to now an american V8.
                        I bet he wrecks this car before he has chance to change the oil again, much less come up with the thousands of dollars needed for a good swap.
                        Ban?
                        www.gutenparts.com
                          • 34839
                          #57
                          worthwhile on a dedicated track car? sure, I'll agree (except most classes have a minimum weight, so you don't want to remove just anything). But on a daily? what could he be doing on his way to his job at Taco Time that a 10lb weigh savings would be helpful? Racing Civic HX's light to light?
                          There's a Mitsubishi Evo running around town that's completely stripped - down to the passenger mirror and door handles (WTF). he showed up to an autox once and got schooled by a stock kia rio on cheap all seasons. but he still has to drive from A to B in what is basically a parts car..
                          • DSP74
                            • Nov 2007
                            • 1121
                            #58
                            It's hard to get into the mindset that ALOT of E30 owners are ricer boys. I tend to forget....To many hacked together jobs. with 120 hp.
                            Yeah BUT guys like that are the absolute BEST to watch get beaten. I could go on and on of stories. Needless to say a Camaro doesn't command as much respect as a vette, audi, porche, viper etc....My old autox car was a Camaro...
                            88 325is
                            • Turf1600
                              • 9815
                              #59
                              Been hanging out at e30tech?
                              • DSP74
                                • Nov 2007
                                • 1121
                                #60
                                E30 tech isn't as bad as the E30 section of bimmerforums!!
                                88 325is
