oil light
  • rede30
    • 4697
    oil light
    i got the motorfired up, that i had just dropped in. now the oil light wont go off, i ran it for a while and made sure i have enough oil. it just wont go off. after running the motor for a little bit it starts to die then kicks back up and just doesnt idle very smooth, and when i start the car it fires then goes low and almost dies. so what coudl be causing this nonsense. thanks.
    Dustin
  • Digitalwave
    is a poseur
    • 6299
    Which oil light? If its the oil pressure, don't run the motor anymore until you find what the problem is.
    RISING EDGE
    • rede30
      • 4697
      yea the light on the check display on the roof
      • Digitalwave
        is a poseur
        • 6299
        Oh, well that is just the oil level light. If you know the level is fine, then its probably just the oil level sensor. I wouldn't worry about it.
        RISING EDGE
