front bumper wont come off
  • Schneider325
    • May 2004
    • 3818
    Originally posted by e30Matt
    Originally posted by Schneider325
    well im using a 19mm socket
    and im not down on the ground, i was just on my knees turning it to the left
    Were you pushing the bar to the left or to the right?
    I was pushing it to the left i believe, i'll try again today
    • Schneider325
      • May 2004
      • 3818
      ya i tried again....its not like its really tight or anything, its very easy to turn. I keep on doing and doing it. I cheacked the bolt to see if it moved down any and nope, it stayed were it was. And this is for both of them. If there a possibillity that i sprayed toooo much PB on it?
      • e30Matt
        • 5077
        There's no such thing as too much PB.
        • Schneider325
          • May 2004
          • 3818
          ok well i gave up on that for a while and im taking apart the interior lol... I got everything i want out soo far execpt the front seat.... I have done it twise already and this time i just cant get this one bolt out... there not enough room to get it out for some reason. Plus on the passenger seat, from the last time i took them out, I couldnt screw in the 2 back bolts. :roll: I have tried just using a wrench since i can get it in there better but the biggest one i have is 15mm. Have any of u guys have any of these problems?
          • DrMcDave
            • 1793
            sounds like my issue i had. worst case scenario the bumpers can be drilled off, and its not actually all that hard. You don't drill the big bolts though. remove the plastic trim, remove then remove the plastic cover and what you are left with is the fiberglass bumper. once you are down to that simply drill out the bolts that attach to the bumper shock. This is what i had to do with the bumpers Etasport now has on his car. It took a while and a 1/2 hp drill running off my air compressor but those fuckers came off.
            • Digitalwave
              is a poseur
              • 6300
              RISING EDGE
              • e30Matt
                • 5077
                Oh no. TJ's got Rob's disease.
                • JonG
                  • Mar 2004
                  • 92
                  Originally posted by Eurospeed88
                  Get a breaker bar and put some elbow grease into it. They'll come off, trust me. They haven't been touched in 15 years.
                  what is a breaker bar? and those bolts mighta been worked on...she was in a little crash about 5 years ago...damn mini van mom pulled out and hit the front cornor of her car.... front bumper/fender i think.
                  a breaker bar is a pipe that you slide onto the handle of a wrench so that you can get more leverage. the longer the bar, the more leverage. makes things alot easier. any pipe will do.
                  • Schneider325
                    • May 2004
                    • 3818
                    i dont need more leverage at all.... it turnes pefectly fine.... what im guessing is the bolt is moving when im turning it backwards then when i go forwards again to take it off, it just goes back to were i started off. a never ending process. how the heck can i take off the trim without the bumper off. that would be a pain in the ass... btw i dont have a fiberglass bumper, its metal
                    • Digitalwave
                      is a poseur
                      • 6300
                      SO KEEP SPINNING IT THE WAY IT GOES WHEN IT LOOSENS AND DONT GO BACKWARDS AND TIGHTEN IT AGAIN OMGWTF
                      RISING EDGE
                      • BMW BMXER
                        • 2325
                        Or he stripped/broke/fucked something up.
                        Sold it.
                        • Schneider325
                          • May 2004
                          • 3818
                          well considering that when use a ratchet u gota turn it back and forth, then it looses and takes of a bolt :roll: Im just saying sumthing is proably fucked up so that is why the bolt is turning in both directions, and not just the one..... I got an idea for today
                          turn to the left... take it out and do it again....I'll see if it works.
                          • Digitalwave
                            is a poseur
                            • 6300
                            Then its probably just finger tight. Disconnect the ratchet and just use the hex to spin the bolt out, so when the ratchet back-steps it doesn't re-tighten the bolt.
                            RISING EDGE
                            • Psychomofo
                              • 95
                              it took you that long to figure that out? you don't use ratchets too often do you? :roll:
                              • rs4pro3
                                • 5808
                                Ok my parts car that was hit in the front had this problem with the one bumper shock, when it got hit the welds holding the nut to the car broke so the nut just spins and spins. If this is the case you'll have to drill it out but that is my guese.
                                85 325e 2.7 ITB'd stroker
