vibrations
  • mitch500
    • Jan 2006
    • 1092
    vibrations
    ok so i have been having this front end vibration for a little while now. now that i have some cash to fix it i want it gone.... anyway it starts to shake the steering wheel ever so slightly when im excelerating up to 60mph. i can feel it in the driver side wheel. if i pick up the speen to say about 80mph then it kinda goes away........ also i notice if i kinda weave back in forth to see which front wheel it was coming from, you can feel it shake alot when you make a slight right turn at a higher speed putting the weight on the front left wheel. anyways im sure this could be a lot of things, just wondering if someone can narrow down my search. thanks
    1988 e30 alpine white vert 5speed
    1987 e30 325 eta
    1983 e28 533
    2001 x5 4.4l
    1997 e36 M3 Alpine white 5speed
    1991 Jeep XJ I6 4.0
  • TwoJ's
    • Oct 2005
    • 4908
    Sigh... there is a number of different things that it could be. How are your CAB's? Upper strut mounts? Are your wheels/tires balanced? Bent?
      • 34847
      jack up the front end, and wiggle that wheel back and forth. my car did something pretty similar to that when the outter ball joint went bad.
      • blunttech
        • 12850
        its helpful to have a second pair of eyes while you do this too. if you see any slop anywhere id think about just biting the bullet and refreshing everything. i hate chasing vibrations. you get one fixed and 2k miles later wear shows up on the next weakest link.
        sales@blunttech.com
        www.blunttech.com
        Like us on Facebook
        • george graves
          • 20003
          Tire imbalances will often occur multiples of the same speed. For example a shake at 40 then at 80 (and god forbid you try to make it to 120)
          Originally posted by Matt-B
          • mitch500
            • Jan 2006
            • 1092
            yes the suspention was some what refreshed...... new bilsteins, h&r's. ireland engineering camberplates.(pretty much new).... new ball joints about 2-3 years ago and tie rods.... not sure about the controll arms they could be ol.d..... the cab's looked ok when i looked. one thing i did notice is that the rubber boot was torn on the outter balljoint... im pretty sure i did this with the pickle fork about 6 months ago. i did put alittle bit of automotive goop to seal the slight tear so no shit got in there. im going to further investigate. thanks.
            1987 e30 325 eta
            1983 e28 533
            2001 x5 4.4l
            1991 Jeep XJ I6 4.0
