intake manifold removal
  • randomtask37
    • 3154
    ive gotten all of the stud bolts removed and the manifold is almost off but it seems that this thing is the only thing holding it onto the motor. i dotn know how to get it off. any tips?
    attached to the manifold
    attached to the block
    98 M3/4/5
  • Kondour
    • 243
    just pull down on the tube, the spring will compress more and it will pop right out.
    • Jordan
      • 12913
      Push down on the spring loaded tube of death.
      If it doesnt move, push down harder.
      https://mtechniqueabs.com/
      • randomtask37
        • 3154
        ah, ok. pushing it never crossed my mind.
        thanks.
        98 M3/4/5
        • Spaz
          Crazy Canuck
          • 2276
          yup that thing is death.
          Cam .W '91 325is
          Spaz's 1991 Alpine White???? S52 Build Thread...
          • Digitalwave
            is a poseur
            • 6298
            Reinstalling it is even more of a pain :(
            RISING EDGE
            • DrMcDave
              • 1793
              zip tie it down before you put it back in, then when u have the manifold in place. snip, snip and you are ready to go. I did this when i did my head gasket and it worked out great.
              • bmwannabe
                • 900
                yeah, its the tube of death. what the hell does it do again? isnt it some sort of crank case vent? i had my own personal bout with the damn thing. when taking off the manifold, watch yuo dont shear off your coolant temp sensor too.
                • Ryan Stewart
                  I Love Miatas
                  • 8978
                  Wear a welding helmet, we dont need anymore injurys.
                  It allows the pressure to be equalized down in the crankcase.
                  Im now E30less.
                  • AndrewBird
                    The Mad Scientist
                    • 11898
                    You know, when Eurospeed and I were parting out the last parts car, the Tube O' Death came out really easy. I couldn't believe it. It just slid down and out of the way. IT was the only thing on the car that wasn't done half-assed.
                    Andrew
                    • randomtask37
                      • 3154
                      well i got it out. it wasnt so bad afterall. probly having such easy access to it really made the difference though.
                      i just attached some clamp-plyer things to it. then put a hammer handle onto the plyers then beat the head of the hammer with a rubber hammer and it came out after only a few wacks.
                      98 M3/4/5
