Rear Sub-frame Brace
  • DCColegrove
    • 2748
    The e30 sub frame bolts are (after a fashion) held in double shear. There are plates that triangulate off of the belly pan to rocker panel bead.
    ...Is this enough?
    There is some flex back there and I have been told this is slowing things down on track times.
    I have seen braces for the rear subs built for the Z3...They look like they were designed by a Briggs and Straton lawnmower engineer.
    The question here is:
    Should Evolution Zen / Mason Engineering turn our attention to this and develop The killer rear brace for the E30?
  • Teaguer
    • Sep 2004
    • 6167
    I think you already know the answer to this . ;)
    • DCColegrove
      • 2748
      Yeah...
      I know....
      An elegant solution...
      To a complex problem...
      Brain Damage Time.
      • sharky
        • Jan 2005
        • 2672
        Yes, If all the mason bars upper and lower are put on a car will the planets all align and make my E30 even more uber supercar than it already is. J/K definetly do it.
        • BeirBrennerE30
          • 2740
          yes... do it!
          e30sport.net
          '06 M3 Competition - 6-speed
          '97 Range Rover Vitesse
          • WillisE30
            • Jan 2007
            • 831
            The answer that should have been obvious as others have said...yes
            sigpicFormer professional wrench thrower.
            Current:
            1988 325is S52
            Former:
            2008 Sparkling Graphite M3 Sedan(victim of home ownership)
            1988 M5
            1996 328is
            • DCColegrove
              • 2748
              :hitler: the e30 is already the Uber Kar...
              With our chassis braces it becomes the FW-190 of the streets.
              • PiercedE30
                • Apr 2005
                • 4220
                Make BeirBrenner happy and make it out of carbon.
                My 2.9L Build!
                • DCColegrove
                  • 2748
                  I think we'd make it out of unobtainium salvaged from that crashed flying saucer John found behind the barn.
                  • thull
                    • Aug 2005
                    • 191
                    How about a replacement for the subframe made completely of tubular steel with adjustable everything.
                    Now that would be an elegant solution
                    Brian
                    89 M3 2.5 - 91 318iS - 91 325iX - 06 X5 4.8iS - 03 525i Touring - Some 91 850s, and a few parts cars...
                    • DCColegrove
                      • 2748
                      Elegant...
                      No...
                      That's the unlimited budget shotgun approach.
                      (I do that too... But you can't buy it off of the website and install it yourself.)
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        Daniel you know you should do it. I told you on Saturday than you should.
                        remember. . .
                        e30_Fiend
                        • Funkmasta
                          • May 2004
                          • 7185
                          How about just a stronger rear mount/brace?
                          With new/aftermarket bushings, I dont see flex being an issue if the rear is solidly mounted.
                          And at that, The new braces would not be worth much to someone in the know...
                          ... You and I had a brief talk about tooling cost @ the fest if you recall
                          Joe Funk -- Portland Oregon
                          That Guy.
                          03 X5. 3 liter obviously.
                          • DCColegrove
                            • 2748
                            It seems that the problem is that with stiff or solid SF Bushings they are twisting around a bit.
                            The little plates that hold the bolt in double shear to the body lip don't quite do it ( :eeek: New info to me just this past Monday)
                            • CorvallisBMW
                              Long Schlong Longhammer
                              • 13039
                              I also noticed that all the Z3 bars go under the exhaust. But my car has more than enough clearence for a bar to go above the exhaust, so it wouldn't reduce ground clearence.
