Something is wrong!!!
  • lov-e30
    • 16548
    We purchased a cherry 91' 318i for my brother and everything seemed right on the car. After 2 days of driving it, the car stalls while in motion and it will turn back on when you turn the key and do the same thing after a while.
    We have checked the battery cables, the spark plugs and wires and all is good we thought that maybe the coils?, but I 'm not sure, has anyone had the same problem? it's a little frustrating and he (my brother) needs his car as a daily driver. can anyone chime in.
    @IRON-E30 aka Edwin:D
  • Teaguer
    • Sep 2004
    • 6167
    Power connection or fuel pump/relay related .
    Does it just cut out/off or does it stumble a little before it dies ?
      • 34844
      sounds like a relay to me
      • george graves
        • 20003
        Bad ecu? I've seen that before.
        Originally posted by Matt-B
        • lov-e30
          • 16548
          it stumbles a little at times, while at a stop light or just on neutral, before it cuts off.
          • lov-e30
            • 16548
            can u enlighten us a little please
            • lov-e30
              • 16548
              which one do you suggest?
              I don't know how to multi-quote so bare with me.
              • E30_fiend
                • Apr 2006
                • 7348
                +1 on the relay being the problem. Damn see if Joey has one he can give you. Its either a white one or an orange one. Its not in the fuse box either, its under a little black cover on top of the drivers side fender.
                E30_Fiend
                  • 34844
                  If the whole car is shutting off I would look at the main relay and fuel pump relay - they're under the black cover on the driver's side next to the AFM. the one towards the front is the main relay, the one in the middle is for the fuel pump. you can swap the FP relay with the one on the back (which is for the O2 sensor) and see if the problem goes away. the main relay is wired a little different though.
                  • lov-e30
                    • 16548
                    E30_Fiend
                    Hey taylor since you'll be in town on Sat., u think u can give me a hand with my brother's car, I've already had Joey look at it and he was a little confused as to what it was.
                    • E30_fiend
                      • Apr 2006
                      • 7348
                      fur sure brother.
                      • e30325ic
                        • Dec 2004
                        • 491
                        On a '91 318 they are under the cover above the engine on the firewall.
                        1990 E30 325ic (sold for more than I paid for it after 5 Years)
                        1995 E30 325e (in progress)
                        1987 E30 325is (totaled)
                        1990 E30 325i
                        1991 E30 318is M50 PWR
                        1996 E36 328ic
                        1997 Z3
                        2006 F150 Super Crew 5.4L 6.5' bed The work horse (need something to drag all these old BMW's home for resurrection.)
                        • Il Duce
                          Non-Mod M42 Modder
                          • 5040
                          Alternator? How are those brushes?
                          • lov-e30
                            • 16548
                            Well, I think most of you guys maybe right, but the symptoms continue and now it won't shut off all the way, it will just iddle down like it's about to turn off and the check engine light will go on. maybe I misinformed you guys or george graves maybe right, could it be the ECU? I
                            I'll replace both of these things and post back later
                            Thanx for all the quick responses.
                            • lov-e30
                              • 16548
                              not bad either.
