Home Made Petrol/Hydrogen Hybrid $$$ saver
  • Massimo
    • Jan 2008
    • 3207
    So i was watching a news report last night on some mechanic who has converted his old ford falcon to a petrol/hydrogen hybrid.
    Here is how it works.
    1: A canister looking object would be filled with water. Then add electricity converting the water to hydrogen.
    2: This would pass to a bubbler to prevent any flash backs for safty concerns.
    3: Then into the mainifold were it would mix wit the fuel.
    Then to give proof it works they took a similar ford falcon and had them do a 100km freeway run the hybrid used about 5 L/100km and the strandard about 20 L/100km.
    So its a huge differance i wanted to know how this would affect my M42. Would it stuff the computer around and dose this affect the motor in anyway. Cheers
    Here is a link to the news artical http://au.todaytonight.yahoo.com/home
    on the right hand side you can see a MPEG player and the one you want to watch is "Aussie Brothers Run Car On Water"
    Thanks Massimo
  • Turf1600
    • 9815
    Sounds neat. I imagine it takes alot of engineering skills and special equiptment?
    • Massimo
      • Jan 2008
      • 3207
      Oh yeh forgot to mention cost $100 to make, bought all the stuff from the hard wear shop and if this guy can make it i can to.
      • JPL
        • May 2005
        • 774
        special equipment? all you need is some water and electricity. i have both. someone make a diy. i'm going to put a gallon of water in my gas tank
        Originally posted by Hawt drift chick
        Yeah, i'm a good dude i swear, i just like to be balls to the wall.
        • biglar
          • Mar 2007
          • 26
          yea well.. i wouldnt put water in your gas tank. Make sure you know what you're doing before ruining your car.
          2005 M3 6MT
          1991 318i - project car
          1997 Civic CX Hatchback - DD
          www.clutchstopper.com
          • PiercedE30
            • Apr 2005
            • 4220
            You do realize that making hydrogen from water is a negative energy process, right?
            My 2.9L Build!
            • SpecM
              • Oct 2005
              • 4531
              -No one else here knows what that means... j/k
              -But you're right. All convertions of matter or energy have waste, therefore you are technicly DECREASING fuel economy in the long-run. Ten bucks says this is going to be a long and bloody thread...
              1989 cirrisblau-metallic 325i
              • FLUTE007
                • 485
                tried it, dosnt work..........
                • george graves
                  • 20003
                  WTF are they teaching in schools now-a-days?
                  Ask yourself this: So if this works - why not remove the gas tank all together? Use a battery to start making Oxygen and Hydrogen - burn that in your motor, and then use the electricity generated by the alternator to make MORE oxygen and hydrogen! WOOOT! FREE ENERGY MAN! JUST ADD WATER!
                  Really people - take a "physics for English majors" class.
                  Originally posted by Matt-B
                  • SpecM
                    • Oct 2005
                    • 4531
                    -Kinda sad how people still try
                    • DCColegrove
                      • 2748
                      http://en.wikipedia.org/wiki/Perpetual_motion
                      Good question....
                      It bends my mind that anyone buys into this shit.
                      • Massimo
                        • Jan 2008
                        • 3207
                        I understand that by this process you will have waste but how dose it affect you fuel economy in the long run?
                        • george graves
                          • 20003
                          Ummm - going out on a limb here: DECREASE IT???
                          • Massimo
                            • Jan 2008
                            • 3207
                            OH SH*T sorry trying to work and read at the same time not a good idea.
                            Anyways im interested in put this into a dd if it works would be awsome. Just wanted to know what this would do to the engine. Not looking for any performance gains just fuel economy.
                            • etxxz
                              • Feb 2006
                              • 2085
                              Let me put this into simpler terms.
                              separating Oxygen and Hydrogen from water by Hydrolysis...that is putting a current through water. You have a cathode and an anode, the water is the electrolyte most of you know what happens. Now you have Oxygen and Hydrogen.
                              Okay now lets talk energy. It takes MORE energy to separate water into Hydrogen and Oxygen than you can get out of burning Hydrogen...that is what your engine does..its an air pump by combustion.
                              At the end of the day, you're using gas to electrolize water with some factor of efficiency (most likely a decent to poor one) and in terms dumping that "HHO" gas as people call it (H2,O gas) into your very inefficient engine and here you start a cycle of wasting energy that makes your car less fuel efficient.
                              from another point of view, your ECU pretty much works off your O2 sensor, most cars will have problems running some dose of this HHO gas, too much and you'll probably stall. there are people that run their cars on water but it is a completely different story and they don't use their car's alternators to generate their fuel; that would defy the first law of thermodynamics.
                              thank you. good night.
                              No more e30s for me.
                              88 black BMW OBDII 332is dedicated track [sold]
                              88 BMW OBDII bronzit 332is [RIP 03/08]
                              91 BMW 325i [sold]
                              86 Corolla 'Ae86' HB 20v trd [sold]
                              http://youtube.com/watch?v=pTj7Hn9v5Rs
