E30 How To Article / Write up.
  • DCColegrove
    • 2748
    If I was to illustrate and write up something...
    What should it be about?
  • DSP74
    • Nov 2007
    • 1121
    flaring fenders for big autox tires, rear subframe removal and complete rear bushing swap, diff rebuild with ramp angles modified, header install/dyno time, manual window conversion.............
    88 325is
    • DCColegrove
      • 2748
      You forgot to add... Drivers sphincter pucker factor telemetry to the list.
      lets try something little first...
      • bimmer_E30
        • 5001
        i am gonna do, how to wash ur e30. hahahaha
        Originally posted by e30e
        • kenika65
          • Aug 2007
          • 1336
          Simple, make a full maintenance how to. I will be making one soon for the M42.
          It will include gaskets, seals, breaks, belts and a few bushings.
          It will teach detail and mechanics.
          1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
          1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
          • Fidhle007
            I can fly, motherfucker
            • Oct 2005
            • 7209
            '89 325is S50 Track Montser
            '04 X5 Daily/Tow Vehicle
            http://www.avarestoration.com
            http://www.myspace.com/brendanfiddle
            Click here if you want to be my zombie slave...
            http://www.youtube.com/user/Fidhle007
            • Nick325is
              • 1409
              Hope it doesn't teach how to break things..
              • Fidhle007
                • Oct 2005
                • 7209
                Do a how to on rebuilding a Ford motor with nothing but a can of spray paint.
                • kronus
                  • Apr 2008
                  • 13032
                  Thread derail in 5 posts! Hodamn!
                  Shifter rebuild guide would be helpful. I'm researching it right now and all I get is "go under the car and replace everything between the hole in the tranny tunnel and the tranny selector rod.
                  cars beep boop
                  • 318isbmw
                    • Nov 2005
                    • 2841
                    I'd do something like doing a brake job and putting in braided lines or something of that sort.
                    • 318isbmw
                      • Nov 2005
                      • 2841
                      Honestly when you look under there, all it is is a circlip which you slide out and then you can pop it loose w/ 2 screwdrivers from the top and it will come out. Very simple. And if you do the actual shift linkage that's a circlip at the other end and a nut is all to get it all out. Very simple. check understeer.com for a full writeup w/ pics.
                      • kronus
                        • Apr 2008
                        • 13032
                        Thanks, that site was helpful.
                        I might as well take some photos of my own when I do this...
                        cars beep boop
                        • DSP74
                          • Nov 2007
                          • 1121
                          I was just messin with ya.
                          Most people could care less about anything on that list....cept' maybe the header install/dyno run
                          88 325is
                          • z31maniac
                            • 17566
                            I also want to see the ebay/IE header dyno run.
                            A rear subframe complete refresh would be nice, subframe mounts, trailing arms, wheel bearings.
                            www.gutenparts.com
                            • homegrone30
                              • Jun 2007
                              • 1449
                              Keyless entry install I havent really found one that makes me want to attempt it anymore, If I do try it I will make a write up mabey even go as far as remote start.
