BMP Oil Filter Heat Sink
  • markseven
    • Sep 2006
    • 5327
    Is anyone running one of these on their M20? If so, is it a major pain to change the filter with this thing attached?
    I Timothy 2:1-2
  • kid325e
    • Sep 2007
    • 6422
    I've never seen one.
    clutchCTRL!
    Move with a purpose.
    - 1991 325iX 4dr/5spd
    - 2000 323i AT
    2016 Mazda CX3 Sport AWD
    • 92 mtechnic cabrio
      • 4907
      Originally posted by kid325e
      I've never seen one, but i found it alot easier to remove the filter from the top of the engine. it's right beneath the exhaust manifold.. I dont think you'd really need a heatshield.
      He's talking about a heat sink, like to help dissipate heat
      R.I.P 07/01/09 - 04/23/10 :(
      • markseven
        • Sep 2006
        • 5327
        Yup.
        Linksterino, neighborinos!
        I Timothy 2:1-2
        • backtrail69
          • Jul 2005
          • 4471
          Waste of money, you already have an oil cooler. If you need to drop your oil temps... which you most likely wont need to with a stock m20 you can upgrade it with -10 lines and whatever size cooler you want.
          :: PNW Crew ::
          '87 325 4dr, '74 2002
          • kid325e
            • Sep 2007
            • 6422
            hmm... very informative. thanks. :up:
            you install/remove the heat sink before you twist the filter on/off. The heatsink clamps onto the oil filter with the two allen screws
            clutchCTRL!
            - 2000 323i AT
            • Jand3rson
              • 37587
              IF you don't tho, such an on an eta, they're a good thing to have. Not that an M20 (i or e) really needs an oil cooler at all anyway, cooling the oil at the filter is good.
              • backtrail69
                • Jul 2005
                • 4471
                i would like to see some data on how much it drops temps... i really doubt its a noticeable difference.
                :: PNW Crew ::
                • markseven
                  • Sep 2006
                  • 5327
                  According to the ad in the latest Roundel, it's on sale for $9.99 plus 10% off for CCA members.
                  I Timothy 2:1-2
                  • Jand3rson
                    • 37587
                    We have one on our replica 1929 Mercedes Roadster, and my father in law has almost always used them on his trucks, especially when towing trailers, campers, etc. His oil temps have always been significantly cooler with them than without.
                    Oil filters get hot as hell. The heat sink is a very simple but very effective device for dissipating heat. They work in all other applications (non-automotive), so it makes sense that they would work on an oil filter. It's the same prinicple as the finned diff covers from an M-coupe.
                    Mark, for that price, I say get one. Even if it doesn't work, you're only out $10. And if it does work, that's all you paid for it.
                    • z31maniac
                      • 17566
                      ^But whose to say the heat sink, which absorbs heat from the filter to pass to the cooler air, won't just absorb head from the much hotter exhaust manifold and leech it back into the oil filter. Since heat always flows to the cooler "stuff."
                      www.gutenparts.com
                      • Jand3rson
                        • 37587
                        A heat sink generally absorbs the heat from the object it's in contact with, not the cooler air surrounding it. Even if the air around it is very hot, it is most likely still cooler than the surface that it's mounted to.
                        • z31maniac
                          • 17566
                          Yeah I know how they work. I'm just saying I can't see it being that effective if says its trying to disappate heat into air thats hotter than the heat sink is.
                          Like the heat sink is 225° but the air around it is 250° because of the exhaust and underhood temps, I can't see it being very effective. Obviously those numbers are made up, but do you get what I'm trying to say?
                          It just seems like an underhood bling/fuh raze mod to me is all.
                          www.gutenparts.com
                          • einstein57
                            • Jun 2007
                            • 10780
                            Some one should relocate the ambient air temp sensor to see what the temp is in that area.
                            www.gecoils.com
                            • markseven
                              • Sep 2006
                              • 5327
                              The idea is simple yet brilliant, and the price is insane. I'll call Bullet tomorrow and ask if we can install it on one of their cars with an oil temp gauge and see if a decrease or increase even registers.
                              Will order one tomorrow...
                              I Timothy 2:1-2
