My i head swap!
  • ClassicScot
    • Oct 2007
    • 90
    My i head swap!
    A quick question, i am doing a i head on an ETA bottom end, i would like to know if i have to change the wiring harness for an eta to an I, i will have a 288 cam with eta block and i manifold.
    Let me know
    Thanks
    Andy
    sigpicWhite Rock Crew
  • StereoInstaller1
    GAS
    • 22679
    Andy, what management are you planning?
    Closing SOON!
    Thanks for 10 years of fun!
    • ClassicScot
      • Oct 2007
      • 90
      explain what you mean.. i have a ECU from and 325 is and i plan on Chipping it. As far as engine management im not going megasquirt or anythin like that at this point.
        • 34839
        yes, you need the wiring harness too.
        • StereoInstaller1
          GAS
          • 22679
          If your ECU is from an early 325i, it should be a 153, later will be a 173.
          These 2 are called Motronic 1.1 and 1.3, respectively.
          They both use the same harness/sensors, but yes, you will need to swap.
          Keep in mind since you are going to a low compression setup, you will lose power by using that big of a cam. Too much "overlap", meaning both intake and exhaust valves open.
          Closing SOON!
          • ClassicScot
            • Oct 2007
            • 90
            as it is i have the i wiring harness installed.. i am having mechanic friends telling me that it needs to be eta not i because of the bottom end and others saying i need the I harness due to the swap.
            Andy
            • ClassicScot
              • Oct 2007
              • 90
              ecu is from an 87 325 is
                • 34839
                you have to use the i harness because the eta harness doesn't have the correct sensors to use with the i ecu. it has nothing to do with what bottom end you have.
                and yeah, a 288 with your CR isn't going to be that great. you'd need a good 10:1 to take advantage of that. it's always possible to shave the head & block a little, but then you need an adjustable cam gear to fix the timing.
                • ClassicScot
                  • Oct 2007
                  • 90
                  ive read that with an i head and eta block i get something closer to 8:1. Maybe an explanation of what i am doing..here it is!
                  i have an I head with a 288 cam, an eta block with 277 000 km, 3 73 lsd, light weight flywheel for an I transmission with an eta driveshaft. If the fly wheel is a problem i can get my hands on a lightened E flywheel. It has a 173 ECU in the car. It is a 325is shell.
                  Maybe that gives more of an insight. the reason i ask all the questions is the mechanic working on the car is saying that "because it is an eta block i will need the wiring harness from the old eta" other mechanics say " not needed, due to a I Intake".
                  After the responses I get off of here and some of the research i have done i should be able to convince them that it can be done.
                  Thanks for your patience and responses!!!
                  Andy
                  • ClassicScot
                    • Oct 2007
                    • 90
                    a
                    • StereoInstaller1
                      GAS
                      • 22679
                      Tell your tech that you need the front crank trigger, build it like an i motor.
                      Don't use that cam until you get higher compression pistons, and some better engine management.
                      Closing SOON!
                      • ClassicScot
                        • Oct 2007
                        • 90
                        whats the downfalls of not doing the pistons and the management?
                        • StereoInstaller1
                          GAS
                          • 22679
                          Big cam + high compression = out of the stock ECUs mapping ability
                          Big cam + Stock E pistons = less power than a stock cam on those pistons
                          If you really want to know more about it, check out this guys page:
                          Closing SOON!
                            • 37828
                            If your mechanic thinks the wiring harness depends on which block you have, maybe look for a new mechanic?!
                            Classic BMW Specialists
                            Grover Beach, CA
                            www.BimmerHeads.com
                              • 34839
                              Andy
                              they're both wrong - mechanics fix broken stuff, they usually don't have a clue how to build something. it has nothing to do with the block OR the intake.
                              aside from the head and intake manifold, you need a 325i crank wheel and all 325i sensors (including the AFM), the 325i harness, the 325i intake boot & ICV, injectors, fuel rail, FPR, coolant sensors, instrument cluster, and the 325i ECU. all the e stuff is basically useless.
