My i head swap!
    • 34844
    Big cam + high compression = out of the stock ECUs mapping ability
    not really - it would run fine with higher CR and a cam, assuming everything is in top shape. But you'll be missing out on a good 10-20hp vs a more modern EMS, which sort of misses the point of doing all this to your motor.
    • Aptyp
      • 6584
      first of, revving his E crank to get full capability of that cam, is dangerous. In most cases., 272 cam's best is beyond 325i redline. So what's going to happen, is this. Your compression will 7.8-8.0. With huge over lap you'll lose the bottom end torque, that E is known for. If you have your stock diff (2.93), going 0-60 will be your Christmas present. You'll have sub E HP by the time you reach I redline.
      Download Desktop Dyno 2000, and just play with it. It's not accurate 100% but you'll get the theory behind what you're doing.
        • 34844
        please, don't post if you have no clue what you're talking about. reving an "e" crank is hardly dangerous. I'm not even going to comment on your cam statement..
        • kenika65
          • Aug 2007
          • 1336
          Lmfao click on my 2.7i how to link in my sig.
          1986 325es (69k) Garage Queen Buy It Now 10k;1986 325es (track rat) 2.7i How-To & 1.1/1.3Motronic UpGrade
          1991 318is (daily driver) 1991 318is M42 Maintenance How-To;1989 325i (parts car)
          • SpecM
            • Oct 2005
            • 4531
            -This is great...
            -yea, the 288* cam is too much for 7.9:1 CR, heck the stock "i" cam is too much.
            -use a 1988 s-eta set-up, OP
            1989 cirrisblau-metallic 325i
            • kenika65
              • Aug 2007
              • 1336
              If your going to do all of this work either buy custom pistons at a compression of your choice with valve reliefs already cut (in case your timing belt ever breaks) or find some super eta pistons and call it a day.
              But here is dyno proof eta + i head.
              So it is a great upgrade from a stock eta.
              • TheEtaUnderdog
                • Jun 2007
                • 841
                if you're doing this swap and you're going to yield 8.1:1 CR. then turbo that bitch! You'll love her, i promise
                Are you kidding me? That nerd doesn't even know how his dick works, let alone a car.
                • ClassicScot
                  • Oct 2007
                  • 90
                  I talked to the tech.. told him about all the research ive done between you guys and strictly eta.net and said that he should treat it like an I build.. he has no problem with that and will be getting things done in no time at all... ill post pics of everything when it is done.
                  Thanks for all of the input greatly appreciated.
                  Andy
                  sigpicWhite Rock Crew
