Went to Drag Strip today, Pictures Inside.
  • Kavkazia
    • 394
    Went to ATCO today, pretty nice day, not many people, got to run 3 times!
    First Run,
    14.926 at 93.66MPH
    Second Run,
    14.961 at 92.87MPH
    Third Run,
    15.007 at 92.46MPH
    Messed up third run because I forgot I lowered tire pressure, and it had better grip, so I launched little bit soft.
    I was running 4.5-5.0PSI
    Mods.
    T3 Turbo
    19lb Injectors
    Stock FPR
    FMIC
    2.5" Full Exhaust with Cat and Flow Master muffler.
    Here are some pictures!
    Later,
    Amirani
    95' M3.
    90' 325i Turboed.
    87' 325eS Fixed.
  • Jon325i
    • 6934
    Nice results. Your first and second run are very close.....consistancy is good 8)
    Jon
    Rides...
    1991 325i - sold :(
    2004 2WD Frontier King Cab
    RIP #17 Jules Bianchi
    • TCD
      • 438
      Excellent. It takes so little boost to make them pretty quick.
      Todd
      TCD
      1985 euro 535i
      503rwhp/485rwtq
      • windsor318is
        • Mar 2004
        • 688
        nice runs, is your car a 325 turbo?? what kinda boost are you running??
        • ColdAccord
          • 5926
          geez. only high 14s and you're forced induction?
          im not trying to be rude, I would just have expected better nubmers
          i'm glad my e30 will be my quick, good handling car, and my other 2 vehicles are the fast ones
          Originally posted by blunt
          • ColdAccord
            • 5926
            i can't see too well cause it's kinda blurry. but are your 60' times in the mid to high 2s? (sorry if they're not, I just can't read too well). that may partially be the culprit
            • Kavkazia
              • 394
              Thanks!
              It's not bad, I was expecting low 15's because I'm running very lean, I have pretty accurate ATR A/F and shows everytime I step on it, and get in the power band, motor leans out pretty bad, and because of it, I have no top end but I ordered FMU, will tune it, and go back to the track again, and hopefully, I do better.
              95' M3.
              90' 325i Turboed.
              87' 325eS Fixed.
              • Kavkazia
                • 394
                On 17's I was pulling 60ft 2.279, like I said, without launching hard to avoid too much wheel spinning.
                Was running 4.5-5.0 PSI, and running very lean.
                95' M3.
                90' 325i Turboed.
                87' 325eS Fixed.
                • E30godz
                  • 1524
                  4.5-5 PSI is VERY low isnt it? i thought launching soft was more like 23ish PSI
                  • graphik
                    • 361
                    he meant tire pressure.
                    • Spaz
                      Crazy Canuck
                      • 2276
                      you should run around 28-20 psi on ur tires, no lower, unless u have drag radials.
                      Cam .W '91 325is
                      Spaz's 1991 Alpine White???? S52 Build Thread...
                      • Digitalwave
                        is a poseur
                        • 6293
                        I am pretty sure he meant his turbo was pushing 4.5-5 PSI.
                        RISING EDGE
                        • brodee
                          • Jan 2004
                          • 2914
                          Bet the times would be a little better if he was running 23psi to the turbo
                          "Modern cars may be able to outgun it, but few can match its character, its motorsport spirit, and the way it plasters a huge grin on your face at any speed." - Patrick George
                          1988 M3 - Track Rat
                          1989 325iC M50 Vert
                          1989 325i Coupe
                          1991 318is
                          1995 318ti Club Sport
                          2006 330i e90
                          2008 Tundra Crewmax
                          • Kavkazia
                            • 394
                            I meant boost 4.5-5.0PSI, not tire pressure, I was running 25PSI in tires.
                            95' M3.
                            90' 325i Turboed.
                            87' 325eS Fixed.
                            • E30godz
                              • 1524
                              oh heh, damn.
                              i was looking at your pictures and was staring at the tires expecting them to look like they had nails in them.
