ok i am all for the turbo,, can i get away with just a small turbo no-other mods? i am on a tight budget, i have two turbos one off of a dodge cummins, and the other off a eclipse
well here is my project
The eclipse turbo will proabably work better for a low budget build. You'll need to run some engine management of some sort, megasquirt is probably the cheapest that works.
LSD yes
15-40 oil yes
Do maintenance on the car first. Turbo on the budget, you still looking at about 2k with all the things you'll need.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
all-right this is going to be a great car i think.. now where can i get new seat material for the crappy leather or pleather what ever it is?Comment
Both:)
Man you got a lot of reading to do.
Go forth and scour the net searching for every turboed M10 ( and then general turbo tech ) out there, this is where I started. I know it sounds a little like I don't want to answer your question but it's not like that. A turboed setup home built is NOT a turn key thing, it's either shell out big dollars or understand how to build your own. When you start hitting detailed questions folks will be there to help you. These basic ones that you are making now don't show the commitment required of such a project, there is SO much basic info that is already out there.
+1, do your research, lots of it is out there. there are also so many affordable ways of doing it. Up to 7 psi, you don't need to tear engine apart nor megasquirt, and that will boost you to about 150hp. From there you'll have to spend a little dough here and there. You'll be spending at least a grand in first throws, take your time it won't seem as bad on your wallet. After that for every other gain you'll have to be spending considerable amounts for the HP you want.Both:)
If you're smart (smarter than me) you'll buy a TCD kit. Spend money once, be broke, but don't be an idiot like a lot of people who scavenge for parts, spent a grand in gas alone and blow their engines (like some).
I do have a 4.10 LSD laying around still in need of a home, that's my pitch.
Hit the books, boy.
i think i am going to build the turbo from scratch, i have a plasma cutter and wire feed, so i think i can do all the fab work, i am not going to run a stand-alone yet,, going to start with about 5psi i think that will be enough to FEEL it, evything stock, maybe a cam thers one on ebay, sounds like it can be a little fun,, its used but i can deal with. i think i can put it togeather in the 750$ range i think . and thats not being to modest. how much for the gears???and how do i tell if its got a lsd in it? someone started to pour money in it before me, lots have been done , its got a real touchy clutch, header and new exaust. exaust needs to be welded but all new.Comment
