How much of a drop from M3 Springs?
  • Spencer
    • 767
    Originally posted by e30Matt
    Correct me if I'm wrong, but M3s use the same shocks as any other 3 series short of the '84 318i.
    No, they were stiffer. And I blew my stock shocks in 2 weeks with M3 springs.
    crap - now I don't want to put mine on.
    -Spencer
    • FrustratedMunky
      • Apr 2004
      • 360
      I think it depends on how you ride on them, if you don't do any auto-x or anything like that, and it's just like city driving, I don't think it would be that harsh as to blow in 2 weeks.
      '91 E30 M42 DIAMANTSCHWARZ
      • Digitalwave
        is a poseur
        • 6299
        Mine was city driving (on nice roads) about 10 miles a day.
        RISING EDGE
        • FrustratedMunky
          • Apr 2004
          • 360
          Ah, fer fuks sake... how many km were on the M3 springs when you bought them?
          • kencopperwheat
            King of Kegstands
            • 14396
            Are you 100% certain that your shocks aren't blown right now? Stock Boges don't last that long.
            Originally posted by Gruelius
            • GreekDriver
              • 100
              Son of a bitch! If stock Boges will blow, what other ones could I buy that won't blow and that aren't as expensive as Bilstein sports? The OEMs I'd be buying would be new. New shocks gone in 2 weeks is horrible.
              I'm getting M3 springs btw.
              • Digitalwave
                is a poseur
                • 6299
                60,000-70,000 miles.
                RISING EDGE
                • Z3Jonathan
                  • 289
                  Really doesn't matter how many miles were on the springs... its how many miles are on your shocks. A shock will start wearing out and loosing damping, causing the suspension to bounce more and more after each bump. Eventually they'll just blow (leak) completely. Throwing on shorter/stiffer springs compounds the situation.
                  A spring doesn't really "wear out" per se. After time, it may loose its spring rate some or sag, but it still functions as a spring. A blown shock is pretty much worthless.
                  • Z3Jonathan
                    • 289
                    IMO, you get what you pay for in shocks, especially on a modified suspension. Stock pieces, or their OEM equivalents, are really cost-driven items. OEM shocks tend to wear quickly, and probably have wide production tolerances.
                    • Spencer
                      • 767
                      How do you test this?
                      When I push down on any corner of my car it pops back up to normal height without any drama. It doesn't bob up and down at all. I think this means they are good right?
                      -Spencer
                      • kencopperwheat
                        King of Kegstands
                        • 14396
                        -Spencer
                        It's really tough to tell sometimes with stock shocks and springs...
                        Here's what I would do:
                        Jack the rear end of the car up so that the wheels are off of the ground.
                        Unscrew the two nuts on the RSM off.
                        Then see if you can compress the shock down by hand... if you can easily and it stays where you compressed it to then it's blown.
                        • Spencer
                          • 767
                          Good to know.
                          Thanks!
                          EDIT:Fast reply. Having internet at work rocks - I can check the boards all the time. School starts in 3 weeks at which point I (and my car) go into Hibernation.
