How do I reset the Service lights?
  • kronus
    • Apr 2008
    • 13028
    Originally posted by Jean
    A bit of warning, order that and you get a late model cover.
    Really? My car is an early body, Motronic 1.0, but that is what the plug looks like.
    cars beep boop
    • Kwaaahhh
      • Apr 2008
      • 843
      Originally posted by E30 Cabrio
      Diagnostic connector.
      Unscrewed the black plastic cover, took a large paper clip and doubled the ends of the paper clip by bending them with pliers so the ends of the clip would fit snugly, inserted the ends of the paper clip into the #7 and the #19 pin holes (They are actually numbered if you look real close) turned the key to the "On" position (But don't start the car!) and the lights reset almost instantaneously.
      Removed key, removed paper clip, screwed the cap back on, closed the hood and was done.
      Different year models will have different Diag connectors, so make sure you do it right otherwise something bad might happen.
      The 1 amp inline fuse is a good idea. I was going to use a length of solder in addition to the paper clip as a "fuse link" but didn't have time and I don't know if that would work.
      What year is your car?
      I think it was different on my 86 es
      Maybe connector numbers 1 and 7 for older E30's/ECU's?
      Thanks for the helpful tip. I got a 90' 325ic.
      • aworthybrother
        • May 2007
        • 899
        FYI: part number was correct. Thanks Kronus, got my cover now.
