How do I reset the Service lights?
  • E30 Cabrio
    • Oct 2006
    • 1954
    It's been a while since I've done this and a search didn't help.
    I have an 88 Cabrio, and need to reset the service light.
    I had my oil changed, but not at the dealer so I need to reset the SI lights.
    I need to find the diagram that shows which pin connectors I need to jump to reset the light(s)
    Anyone have the diagram and instructions?
    I've done it before, but can't find the diagram.
    I had a printout once, but can't find it.
    I believe I have the 173 ECU
    Thanks.
    1988 5 spd.Cabrio/Lachs Silber/Black Leather/123k/Dealer Serviced & Maintained by both PO's
    Clarion DXZ785USB HU, BBS Wheels, Leather e-brake handle & e-brake boot, Mtech 1 Wheel, Maplight Mirror, Performance chip, Rear Headrests.
    Previous E30: 1986 5 spd. 325es/Delphin Gray/Black Leather/191k
  • Sam Cogley
    • Jun 2008
    • 521
    Your friend, Search is.
    • Turf1600
      • 9815
      Just as a tip I use a continuity tester. I clip it onto something grounded and then stick the lead in hole # 11 (I think)
      • Kwaaahhh
        • Apr 2008
        • 843
        Thanks.
        Glad I came across this thread. My light just turned on my 90' vert. So what pin do I need to jump? And do you do it on the diagnostic connector or behind the cluster?
        • Nicademus
          • 2912
          Is that you Yoda?
          Well, posterity, you will never know what it cost us to preserve your freedom. I only hope that you will make a good use of it. If you do not, I shall repent in heaven that I ever took half the pains to preserve it.
          ~ John Adams ~
          • aworthybrother
            • May 2007
            • 899
            my apologies for thread hi-jack - does anybody know the part number for the plastic cover, covering the pins where you connect the rest tool?
            • kronus
              • Apr 2008
              • 13030
              12521286052 for early models.
              cars beep boop
              • aworthybrother
                • May 2007
                • 899
                Thanks a lot Kronus! You made me realized I needed a cover for this. :p
                • kronus
                  • Apr 2008
                  • 13030
                  Hey, my little plastic bag with a ziptie around it held on fine for my whole cross-country trip. This just looks slightly cleaner.
                  cars beep boop
                  • E30 Cabrio
                    • Oct 2006
                    • 1954
                    Thanks, Sam. Paper Clip and Pins 7 & 19 FTW
                    • Jean
                      • 18228
                      A bit of warning, order that and you get a late model cover.
                      • Sam Cogley
                        • Jun 2008
                        • 521
                        Originally posted by Nicademus
                        Is that you Yoda?
                        Found me you have.
                        • Kwaaahhh
                          • Apr 2008
                          • 843
                          So did you jump the diagnostic diagnostic connector or behind the cluster?
                          • E30 Cabrio
                            • Oct 2006
                            • 1954
                            Diagnostic connector.
                            Unscrewed the black plastic cover, took a large paper clip and doubled the ends of the paper clip by bending them with pliers so the ends of the clip would fit snugly, inserted the ends of the paper clip into the #7 and the #19 pin holes (They are actually numbered if you look real close) turned the key to the "On" position (But don't start the car!) and the lights reset almost instantaneously.
                            Removed key, removed paper clip, screwed the cap back on, closed the hood and was done.
                            Different year models will have different Diag connectors, so make sure you do it right otherwise something bad might happen.
                            The 1 amp inline fuse is a good idea. I was going to use a length of solder in addition to the paper clip as a "fuse link" but didn't have time and I don't know if that would work.
                            What year is your car?
                            I think it was different on my 86 es
                            Maybe connector numbers 1 and 7 for older E30's/ECU's?
                            • E30 Cabrio
                              • Oct 2006
                              • 1954
                              Stolen from one of the links above:
                              Insert the ends of a big paper clip, a length of wire, or whatever you have handy that will work, into the connectors for pin # 7 and pin # 19, turn the key to the 2nd "On" position and the Service light and the Red and Yellow lights should all reset right away.
                              Just make sure you hit the right holes.
