Idle Stuck at 4,000rpm
  • olskool
    • Mar 2008
    • 77
    It happened again. After driving for several miles, the engine revs to about 4,000rpm and is stuck there, then check engine light comes on, and the engine cuts off.
    I did a stomp test and it shows a fault code of 1262 Idle Speed Actuator. What do I need to do to resolve this problem? Is this the cause to the stuck engine rev?
    I just replaced the alternator. Any chance the new alternator is causing a short circuit to the system?
    Where is the Idle Speed Actuator located? Please help would be greatly appreciated
  • TDE30
    • 7042
    Had this issue with my father's S38, it ended up being the throttle position switch. If these cars have that, I'd look there as well. IIRC, it's right in the vicinity of the throttle body.
    - Trey
    E90 325i/6 (ZSP, ZPP, ZCW)
    E36 325i sedan
    E30 325i sedan
    Volvo 945T
    • DCColegrove
      • 2748
      DME 1.3?
      ISCV (or connections)
      • JAM
        • Feb 2007
        • 524
        make sure the throttle cable doesnt have any broken clips and it isnt getting hung up on anything... as stupid as that may sound...
        Originally posted by Mr Watsonsilver
        driving boards?
        • olskool
          • Mar 2008
          • 77
          Originally posted by DCColegrove
          DME 1.3?
          I checked the icv connections and also cleaned the icv with TB cleaner.
          Not sure I understand your first question though "DME 1.3?"
          • BMWLA
            • Jul 2008
            • 407
            the idle valve is shot what DC is talking about is what Motronic system you are talking about.
            when the ICV goes bad on the 55 pin DME (v1.3) the idle either shoots to 4k or wont idle at all.
            • olskool
              • Mar 2008
              • 77
              How do I find out which version Motronic I have?
              Also, when the ICV goes bad, does the idle shoot up to 4k rpm and stays there before the engine cuts off by itself, much like what I am experiencing?
              • DCColegrove
                • 2748
                9/87 up is DME 1.3 (55pin Bosch Motronic). The ISCV (Idle Stabalizer Control Valve) will have 3 wires rather than 2.
                and that's what they do when they go kaput...
                4k or nothing.
                • reelizmpro
                  • 9558
                  Idle Control Valve like the others have stated. Assuming you have a 325i, make sure you get the right valve. Early cars had an "L" shaped valve and later 89-on cars had a "T" valve. They also use different boots. What is the year and model of your car?
                  88 M3 - LACHSSILBER
                  89 M3 - ALPINEWEISS II
                  • combustion325ix
                    • 73
                    Im gonna go out on a limb here and disagree with everyone else. My theory is that your car wants to go fast and when you freak out and start stomping the throttle instead of dropping the clutch your car is like screw you i will throw a cel and shut down since you wont let me run wild. Or your car could be a decepticon
                    • BMWLA
                      • Jul 2008
                      • 407
                      :drink:good call i think you may be right here
                      • olskool
                        • Mar 2008
                        • 77
                        It's a 1990 325is and it looks like I have the "T" valve. Damn, Bavauto has it priced at $168. I sure hope a new ICV solves the problem. Thanks everyone for your input. I'll let you know how it turns out.
                        • kid325e
                          • Sep 2007
                          • 6422
                          hahaha.
                          clutchCTRL!
                          Move with a purpose.
                          - 1991 325iX 4dr/5spd
                          - 2000 323i AT
                          2016 Mazda CX3 Sport AWD
                          • Reign
                            • Nov 2008
                            • 125
                            Well, instead of gambling, why don't you take it to a good mechanic and making sure that's the problem. It's a big issue for someone to gamble on and hope they are right.
                            '91 318iS
                            Koko's Garage - BMW and Mercedes Specialists
                            651 Mount Auburn St, Cambridge, MA, 02138
                            Selling This Car:
                            http://r3vlimited.com/board/showthread.php?t=132392
                            • BMWLA
                              • Jul 2008
                              • 407
                              no srsly it is the ICV for sure
