Idle Stuck at 4,000rpm
  • olskool
    • Mar 2008
    • 77
    I unplugged the ICV and started the car just to see what would happen. It actually idled smoother so I drove the car for a couple minutes, idle did not stick to 4k rpm, but the idle eventually went lower and lower then the engine cut off. I plugged the ICV back in and the idle went back to "normal," but I don't think I have since driven it long enough to trigger the stuck idle problem again.
    Is there any other way to test the ICV to determine if it is bad?
    • DCColegrove
      • 2748
      Dude...
      If the DME and the wiring is good...
      The ISCV is bad...
      That is what they do when they are bad.
      • olskool
        • Mar 2008
        • 77
        Originally posted by DCColegrove
        Dude...
        The ISCV is bad...
        Alright, man. Thanks.
        • reelizmpro
          • 9552
          Get a known good one and swap it out. I had a few of those that I sold for $20 each.
          88 M3 - LACHSSILBER
          89 M3 - ALPINEWEISS II
          • olskool
            • Mar 2008
            • 77
            Thanks, that's what I'm looking to do. You got any more?
            • robspeed325i
              • 403
              Also check your motor mounts. Your engine might be flopping around unbeknownst to you and hanging up the throttle cable. probably unlikely given the CEL and shutdown thing, but never hurts to check. i mention this because it is a common problem with 02s (my baileywick) that have broken their DS mount. Engine moves over, pulling on throttle linkage, car revs out of control. anyway just a thought. :)
              • olskool
                • Mar 2008
                • 77
                I will check it out, but I doubt it's the problem, because sometimes the high rev happens after the car sits idling normal for awhile on the driveway.
                Another thing that happens is that sometimes when the car is sitting idle and I slam the door shut, the engine cuts off. Or when I slam the glove compartment door shut, the idle surges. Any thoughts?
                • robspeed325i
                  • 403
                  im new to e30s but is the DME box under the dash? maybe you got bad connex.
                  • olskool
                    • Mar 2008
                    • 77
                    Yes, it is under the dash above the glove compartment. I'm going to check the connections, too.
                    • Jordan325iC
                      • Aug 2005
                      • 1697
                      I've got an ICV. It was sold to me as good but I never did get a chance to put it on my car (ended up being a bad TPS). $15 shipped. PM me if you want it.
                      '88 325is
                      VP UT of Austin Autoholics
                      BMWCCA 380364
                      • tg318is
                        • Jun 2008
                        • 2052
                        this happened to my old e36.. i just had to fiddle with the accelerator and it went back down to round 800rpm.
                        Tim.
                        • olskool
                          • Mar 2008
                          • 77
                          I have a 90 325is and requires the T-shape ICV. Is your ICV T-shaped?
                          • robspeed325i
                            • 403
                            could be the connex to the box or a component *inside* the box has come desoldered. possibly pull glove box and investermigate with small hammer/knuckles... ;)
                            • reelizmpro
                              • 9552
                              Yes, please make sure it's not a sticking throttle cable before swapping the ICV. This is common on E30 M3's but not so much on 325's. It's still something to check for though.
                              88 M3 - LACHSSILBER
