Originally posted by sticksdaman
View Post
Has anybody blown the rear shock mounting point?
I've got them in my car, I found this link when I was redoing my RSMs:
51-71-8-413-359
AKG makes a set as well.
'91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
'87 535i - Vacuum brake conversion [SOLD]'93 525iT - 5-speed swap - 320k and counting'09 328xi - 6-speed
Got it... Reinforcement plates.Originally posted by Gooch View PostI've got them in my car, I found this link when I was redoing my RSMs:
51-71-8-413-359
my rear subframe mounting point ripped out of the sheet metal under the rear seat. no rust on the car what so ever... i reversed over a baseball sized rock behind my car at the BMW dealership when i was picking up parts... the rear left wheel hopped over it and the mounting point pulled right threw..... i was pissed.1988 e30 alpine white vert 5speed
1987 e30 325 eta
1983 e28 533
2001 x5 4.4l
1997 e36 M3 Alpine white 5speed
1991 Jeep XJ I6 4.0
Anytime :up:Originally posted by madformx5 View PostI need to do this to my car too. Thanks for the info Gooch
So, I finally decided to pull out the lining in my trunk and change my shock mounts. After removing the old ones which were completely blown, I took a look at the mounting points to see what condition they were in. Well, I must have jinxed myself by asking about this last month because they are both slightly bent, and one of them has a small crack in it.
I guess the play in the worn mounts let the mount impact the sheet metal and bend it.
The moral of the story is do the right thing and change your mounts before its too late.
I'm left to find some way of reinforcing it. The mounts I'm using have reinforcement plates like the ones mentioned above. I'm thinking about welding the plates to the sheet metal to distribute the the load beyond the cracks/bends.
It happened on my '93 325is in '99. At the time I think it was a relatively new problem. BMW sent out some people to take a look at it at the dealership before it was fixed. I later found out that I was not the only one with this situation. :crazy:Originally posted by Motorsports View PostThats very common on E36s
R.I.P 07/01/09 - 04/23/10 :(
