crank sensor and o2 sensor problems
  • der affe
    Technical
    • Dec 2005
    • 8452
    OK here's the story.
    in the almost 3 years i have owned the car, i have gone through 3 crank position sensors. is this common?
    did they have a bad batch of them from Bosch?
    the car starts runs a little then dies, it will die even faster if i try to give it gas an rev it up.
    i have a narrow band O2 gauge that is not showing a signal right now, so that might be my problem too. today it was dieing when i came back down to an idle randomly. i would just pop the clutch and it would restart no problem. when this would happen i had no signal at the o2 gauge.
    right now i went to get in the car and it had no signal and wouldn't stay running.
    last time it was having a similar problem it was the crank sensor.
    does the o2 just fucking die?
    it is only 1 1/2 years old (6 months of which i wasn't driving it because i was in the hospital)
    any ideas?
    i am going to go out and jiggle some wires to see i i have some kind of random short in the o2 harness
  • der affe
    Technical
    • Dec 2005
    • 8452
    never mind, i found a angry wire up under the glove box.
    fuck i want to kill the PO for his shitty wiring job on the piggy back and Dbilas/ford MAF stuff!!!!!
    i am curious about the crank position sensor though, 3 in 3 years seems high to me.
      • 34844
      ditch the piggyback, pick up one of the budget standalones out of AUS, everyone will be happier. :)
      • der affe
        Technical
        • Dec 2005
        • 8452
        i KNOW, but the $$$$ is super tight right now and i don't have the $2500 to spend on it.
        shit, i have been telling everyone on here about WOLF for the last 2 years.
        maybe someday soon :(
        • der affe
          Technical
          • Dec 2005
          • 8452
          is that just a fluke about the crank sensors though?
          3 in 3 years seems pretty high to me
            • 34844
            were they rubbing on anything? The only time I've ever seen them go bad is when they rub on a pulley and short out.
            • der affe
              Technical
              • Dec 2005
              • 8452
              no, that is the weird part. they just crapped out.
              first sporadically then completely.
              i trust the guy who did the work, that he wouldn't lie to me.
              he did warranty out the second one because it had been 6 months and did the labor for free
                • 34844
                does it have a custom wiring harness? That's the only other way I can see it dying. I don't think it even has a Vref signal from the ECU, the voltage is generated in the sensor itself.
                • der affe
                  Technical
                  • Dec 2005
                  • 8452
                  not really, just the piggy back stuff and most of that is added wiring.
                  some times i think the car hates me??????
