Evans NPG Coolant... Anyone Using it?
  • der affe
    Technical
    • Dec 2005
    • 8452
    I'd say the above post is a pretty good testimony for it. VR-6's in those cars run hot for lack of air flow and couple that with the performance/displacement upgrade it should have aggravated the problem, instead it improved it over stock with no improvements to air flow in the front.
    daily driver car, no bitching at all. that says something, because all he seems to do is bitch about things that don't work perfectly.
    just a thought have you tried to run a 70/30 mix with "racing" water wetter? the racing has an added water pump lube in it over the regular water wetter. that is a cheaper way to go, if that will work for what you are trying to do.
    • browntown
      • Jun 2004
      • 3524
      Ancient thread, I know. Anyone tried this lately? Since I'm replacing my radiator,expansion tank, heater core, and all hoses in my m30 swap, it would seem like the right time to do this. My tank will be hot-tanked and there should be no water based coolant residue anywhere in the system.
      Anyone take the plunge $120+ plunge?
