Non-E30 tech question: '91 Nissan pickup
  • Jand3rson
    • 37587
    I have a '91 Nissan pickup, and yesterday, the windshield wipers quit working. When I turn them on, the arms still lift up and down slightly, but only about a 1/4", and the blades don't move at all. It's like the motor doesn't have enough power to move them. If I manually move the arm by giving it a little nudge on the upstroke, the arm will move across the windshield, but won't come back down. And when I do this, the other arm doesn't do anything at all. Anyone have any idea what might be going on?
  • delatlanta1281
    Dart Master
    • Mar 2006
    • 10317
    sounds like your motor is going. Is it making any noise like the gears being stripped? Are the arms screwed down seculrly?
    Yours truly,
    Rich
    you kids get off my lawn.....
    • SpecM
      • Oct 2005
      • 4531
      yea, do they (each arm) move together or indapendantly?
      1989 cirrisblau-metallic 325i
      • jflip2002
        • Sep 2006
        • 4377
        Wiper Motor. 28815-01G00 - $178.84 cost. $296.90 list.
        The arms would move together, as there is only one wiper motor on the truck.
        Originally posted by blunt
        • Jand3rson
          • 37587
          Upon closer inspection of the arms, I can see the little spindles that turn the arm turning back and forth inside where they mount to the arm. It seems like they aren't gripping the inside of the arm base to turn it.
          • kamotors
            • Nov 2007
            • 7102
            this happened to a landrover my dad had, the spindle inside the arm stripped out to we drilled a hole horizontally through the wiper arm and spindle and then put a bolt through it, it worked very well and it was basically invisible.
            7speedshop.com
            • Julien
              • 7471
              Originally posted by kamotors
              this happened to a landrover my dad had, the spindle inside the arm stripped out to we drilled a hole horizontally threw the wiper arm and spindle and then put a bolt threw it, it worked very well and it was basically invisible.
              through
              Build Threads:
              • kamotors
                • Nov 2007
                • 7102
                Originally posted by Julien
                through
                thanks
                7speedshop.com
                • SpecM
                  • Oct 2005
                  • 4531
                  through
                  true
                  Joshie: you need new wiper arms, I see it happen all the time
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    ^^ What he said, or you can cotter it and screw the output shafts up forever, or junkyard some new arms.
                    • Money$hit
                      • Mar 2008
                      • 1604
                      jb weld
                      • AndrewBird
                        The Mad Scientist
                        • 11898
                        Let me guess, turned the windshield wipers on to clear a bunch of snow off? Bad, bad idea. The weight from the snow stops the arms from moving and the motor keeps turning resulting in stripped splines.
                        Pull one off and check to see if the splines are stripped on the arm or on the shaft. Hopefully they are just stripped on the arm.
                        • SpecM
                          • Oct 2005
                          • 4531
                          luckily, most of the time it is just the arm that strips. so much easer/cheaper to replace just the arm!
                          • SamE30e
                            • Sep 2007
                            • 4319
                            Stripped. If you really don't care. Tack weld the arm to the spindle.
                            1985 325e 2.8 Turbo VEMS
                            • eyagel
                              • Jan 2007
                              • 756
                              i have some extra arms. pm if interested, free just pay shipping
