Stuck bleeder screws
  • mikeedler
    • 6707
    maybe you should read up before you play with something like brakes.-----
    I needed to use a pressure bleader on my M3 after it sat for a few months with no fluid-- the ghetto way wasn't doing anything for it.
    • StereoInstaller1
      GAS
      • 22679
      Originally posted by SamE30e
      "SUCK MY FUCKING BALLS!"
      Is what I said when I got the other 3 out, heat and them working them back and forth lightly with vise grips. Fuck the back left i'll just take the caliper off my 325 and put it on there.
      Does anyone know if you have to do anything special to bleed the ABS unit?
      I can only quote GM spec, but they say never to open calipers with the bleeder closed. They want you to spew the dirty fluid out of the caliper so no debris gets to the ABS pump.
      Closing SOON!
      Thanks for 10 years of fun!
      • SamE30e
        • Sep 2007
        • 4319
        Well I don't think there is dirty fluid in the ABS pump. It's all clean brand new fluid. I just need to know if I need to bleed the ABS pump some way.
        1985 325e 2.8 Turbo VEMS
        • kid325e
          • Sep 2007
          • 6422
          I know this will seem like a stupid thing to say but have you checked the bentley?
          clutchCTRL!
          Move with a purpose.
          - 1991 325iX 4dr/5spd
          - 2000 323i AT
          2016 Mazda CX3 Sport AWD
          • SamE30e
            • Sep 2007
            • 4319
            I don't have one.
            So if someone has one, and they can check, that'd be cool.
            • SamE30e
              • Sep 2007
              • 4319
              Fucking stupid.
              I bled them, it was solid as a rock and then I started the car up, and then it went soft again.
              I guess I need to pressure bleed it.
              • AndrewBird
                The Mad Scientist
                • 11898
                To bleed the ABS system, you need a special tool to cycle the plumps. Or you can bleed the brakes and then go drive the car and slam on the brakes. Basically all you need to do is engage the ABS a few times. This will pump fluid into and through the ABS pump. It may not be necessary though.
                And of course, don't be stupid and do this on public streets. Find a nice big empty parking lot and do it there if at all.
                • SamE30e
                  • Sep 2007
                  • 4319
                  Yea, I'm going to try pressure bleeding tomorrow.
                  Is there anyway to actuate the pump while the car is stopped?
                  • SamE30e
                    • Sep 2007
                    • 4319
                    Drove it around the block, the ABS works, the pump turned on, but no fluid drop, so no air there.
                    I'm guessing master cylinder maybe, I'm going to try pressure bleeding them.
