has anyone ever fixed their central locking on an e30?
  • bastianshaw
    • Jan 2007
    • 2210
    #61
    my key fits everything but the drivers door but its like there is no power to the CL system, no clicks, trunk is manual and can be locked same as pass door....fuse? relay? any ideas?
    • F34R
      sLaughter
      • 12376
      #62
      Hmmm, mine locks...then unlocks super annoying.
      Instagram: @BWeissLeather
      Current cars:
      ~ '87 325 M30B35 swap
      ~ '87 535
      ~ 01 540 Msport 6spd
      ~ '06 X5 4.8is
      • Mwishlist
        • Jul 2013
        • 505
        #63
        I am in the same boat, my keys fits everything but I have zero power sound etc. I found this troubleshooting guide that looks pretty solid. Depending on how long it takes to knock out the brake job this weekend, I will take a crack at the central locking and report back.
        Everybody who have a BMW E30 knows that it's a miracle to have a fully working central locking. But the most of us dont have it fully worki...
        Thank god, R3V was getting boring since the ginger kid wrecked his car. - Stonea
        • bastianshaw
          • Jan 2007
          • 2210
          #64
          http://nomad-bmw.blogspot.com/2012/1...ng-issues.html
          this is good info
          • Kevinl
            • Oct 2012
            • 897
            #65
            mine works ok but it seems like when it is cooler out side the key wont lock the drivers door without a couple tries
            1989 BMW 325is Lachsilber metallic 5 speed
            2007 BMW 335i KARMESINROT 6 Speed manual
            2011 BMW X5 35I
            • Navarone
              • Jun 2014
              • 935
              #66
              I need to do this soon, passenger side is stiff, driver side doesn't lock all of them. I have to lock from the trunk to make all the locks work. But hey, at least they lock!
              Here's another article.
              http://bmw.e30tuner.com/articles_lockrebuild.php
                • 34847
                #67
                Anyon ever remove the lock cylinder on a 4 door? I'm guessing i need to get the window regulator out of my way..
                • Mwishlist
                  • Jul 2013
                  • 505
                  #68
                  So just to follow up with mine, I found the issue; it was the PO.
                  Actually the key cylinder is shot and will unlock but not lock the door. Because of the (stupid IMHO) double lock feature the lock cylinder arm is I believe solid in one direction but spring loaded in the other direction so you can do the 90 degree turn double lock feature (over-engineered?). SO after years of use it failed in one direction. I am guessing as a result, the PO just went ahead and disabled everything by (luckily) just disconnecting the arms from the actuators and removing the gas cap actuator. By sheer luck I pulled a complete gas cap actuator from a junked 325 a few weeks ago because I happen to see it in the trunk. I plugged it up and bam, if I push the latch in the door with my hand everything works like a charm except the passenger door. I still have to check the passenger door, hopefully the actuator is in there and just disconnected like everywhere else in the car.
                  What sucks is I have the car torn apart and I have to put it back together for this weekend then I will have to take the drivers door back apart to rebuild the key cylinder. Although technically I could just skip that and put wireless entry on it since I know it works now.
                  Anyway, i will report back but I will be using the link provided above to rebuild the key cylinder with a $26 OEM kit from ebay, so thanks for posting that.
                  Hopefully this helps someone else. If you have absolutely no power, no noise or clicking like me, check the red/black wire gong into the unit to make sure it has juice and / or pull the driver door card and move the mechanism to see if it triggers the CLCU. Also, you have to flip the mechanism in the door so it thinks it it closed or the locking won't trigger. I assumed it was electrical which was totally wrong.
                  • Mwishlist
                    • Jul 2013
                    • 505
                    #69
                    Also, on that note the double lock microswitch is missing an arm but I honestly don't want / need this feature. anyone know if I can simply unplug the microswitch and everything will still work? I can just tie it up in the door like the PO but I 'd rather clean up the connections if I can.
                    • AwakenNoMore
                      • Dec 2010
                      • 1291
                      #70
                      mine's never worked since I've owned it, i know the passenger side actuator is gone (i have one to put in) trunk and doors work manually (when i turn the key you can hear a relay click but thats it)
                      1991 325i - "Scambles" The Daily Driven lightly modded.
                      1988 Mazda RX-7 TII "Mako" The Free Dorito
                      bacon by Jared Laabs, on Flickr
                      • spdracrm3
                        • Sep 2009
                        • 959
                        #71
                        looking at wiring diagram indicates you can just leave the micro switch disconnected or removed and the deadbolt/lock inhibit function wont activate but normal locking will function ok as the switches for normal lock/unluck are in the lock motors themselves and as long as they are functioning/connected central locking should work....proof of this is those on which the activation arm on the driver door lock tumbler is broken(common,its the part that hits the microswitch) and they dont have deadbolt/lock inhibit but just central locking.
                        Angus
                        88 E30M3 X2
                        89 325IX
                        92 R100GS/PD
                        • cabriodster87
                          • Jan 2011
                          • 1042
                          #72
                          yes, pnp lockcyl arm and control box fixed it, my driver door dome even started to work.
                          Reich und Roll!
                          • pantelones
                            • May 2011
                            • 533
                            #73
                            Yeah, I have rebuilt the driver door lock. It's just harder to see and work with than the 2-door. No need to touch any window parts, just move the glass up after taking the door card off...
                            Mine was pretty simple to fix... New (to me...) central locking box, and a door lock rebuild kit from pelican did the trick. I followed the directions seen on the link below, and it was really no different with the 4-door.
                            A man chooses, a slave obeys... Would you kindly?
                              • 34847
                              #74
                              move the window up?
                              I can't even get my hands in there to feel around..
                              • Mwishlist
                                • Jul 2013
                                • 505
                                #75
                                So, passenger side was just disconnected like the rest, put everything together and it works like a charm. My tumbler in the drivers side and key works great so instead of pulling the door card again etc I used sone heavy duty wire I have and ran it around the back of the tumbler. Voila, solid turning in both directions. I know it's not a long term fix but there are so many other things to do and with a keyless kit on the way, rebuilding the tumbler is low on my priority list right now.
