Rocker panel molding--is this OEM on a 325i?
  • 88e30is
    • Feb 2007
    • 690
    Originally posted by mtriple
    hideous!!!
    +1
    • td325ic
      • Feb 2006
      • 788
      Originally posted by der affe
      i stand corrected!
      what are the ones i posted then i have seen them advertised as "IS" side skirts
      Looks like they are the later style Zender skirts.
      Originally posted by Chisum
      Saw this car for sale on Ebay, it's a 91, and I noticed it appears to have some kind of ground effect on the rocker panel. Is this OEM? I thought only the iX cars had ground effects. I have a 91 325i and it doesn't have this.
      Yep, they are OEM "is skirts", as the others mentioned
      Here's the part numbers:
      No. Description Supplement Qty From Up To Part Number Notes
      02 COVERING LEFT 1 09/1987 51711947059 $27.20
      02 COVERING RIGHT 1 09/1987 51711947060 $27.20
      03 COVERING LEFT 1 09/1987 51711947063 $108.00
      03 COVERING RIGHT 1 09/1987 51711947064 $108.00
      04 SHEET METAL SCREW B4,8X19 2 09/1987 51711939302 - $1.00
      05 CLAMPING BOLT 2 09/1987 51711933719 - $1.20
      06 PLASTIC NUT M6 2 09/1987 16131176747 - $0.40
      07 CLAMP 2 09/1987 51711922599 - $0.29
      08 PLUG 2 09/1987 51711927439 - $0.38 09 CLAMPING ? 09/1987 51711938940 - $1.15
      10 GROMMET D=9,1 ? 09/1987 51711932996 - $0.20
      11 RIVET 4 09/1987 51111942789 - $0.75
      12 CLAMP ? 09/1987 51711959929 - $0.48
      I just looked up the prices on Tischer BMW...not to bad, I don't know if they're still available but looks to be about ~$220 for the whole setup. I see people selling them used for more than that. Anyone know if is skirts are still available new?
      • Mtriple
        • 3139
        Yes, still available. I bought a set from the dealer last spring.
        Originally posted by Simon S
        • Chisum
          • Apr 2008
          • 229
          Thanks for the quick info. No wonder I never saw these before. They were only available one year! Although RealOEm says 9/87 and later I'm sure that's what years these could be retrofitted to. Does installation of these require drilling holes in my rocker panels and fenders?
          • Teaguer
            • Sep 2004
            • 6167
            Yes , lots of holes if done correctly .
            Or you could bypass the drilling and just adhere the top of the sides with automotive double-sided tabe but may experience some sagging .
            And yes that Calypso car in the first post is an '91 325i with optional "Sport Package" although they only came badged as 325i .
            • gearheadE30
              • Jun 2007
              • 3734
              The skirts are a lot more common in europe, and they were availiable with the advent of plastic bumpers iirc. They are all over the place over there.
              Project M42 Turbo
              • Teaguer
                • Sep 2004
                • 6167
                Yep , stock on all tourings .
                • Jand3rson
                  • 37587
                  der affe, I think those skirts you posted are Zender, I think Cary has the same ones on his car.
                  • td325ic
                    • Feb 2006
                    • 788
                    I thought that too, but Cary has slightly different style of Zenders if you compare the pics closely. I'm assuming the red ones we've been talking about are Zender's later version to go with their kit for plastic bumpers.
                    • guibo09
                      • Dec 2008
                      • 834
                      for all you guys who installed the IS side skirts on a car that didnt come with them:
                      what did you use to attach the smaller front half of the skirt? which hardware did you buy out of 4,5,6,7,8,9 in the oem part break down?
                      90 E30 325i
                      • Chisum
                        • Apr 2008
                        • 229
                        The reserve on the Calypso car (140292169545) is around $5000. The reserve was not met yet at $4200. It's really a clean car with a nice color combo. He says he paid someone $5000 to just rebuild the motor. If you believe that. I thought the car was an 325i with the "s" pkg, but it has no OBC. Did they have OBC in airbag cars? I assume so.
                        I have a 325i non sport but its a cali car and very clean. I'd love the look of the car with the sideskirts but I couldn't bring myself to drill holes in perfectly good rocker panels. Especially in the northeast where rust is pretty easy to start.
                        • BlkD12agon
                          • Jul 2012
                          • 56
                          Sorry to resurrect the dead but will these side skirts fit an '85 model?
                          • mikeedler
                            • 6707
                            they will fit any e30 except the M3 and the convertible no matter what year.
                            • BlkD12agon
                              • Jul 2012
                              • 56
                              Awesome. Thank you.
