I tried that and i made a little ramp thing to drive up on them but everytime i tried it i just ended up pushing it forward. To the OP: Thankfully ive only had to use the factory jack once but it is pretty much useless unless your on a flat surface because it has no lateral support at all.
Is it me or do the e30 jacks blow?
Go buy the cheap $5 rubber floor mats from walmart and cut them up and glue them to the bottom of your ramps.I tried that and i made a little ramp thing to drive up on them but everytime i tried it i just ended up pushing it forward. To the OP: Thankfully ive only had to use the factory jack once but it is pretty much useless unless your on a flat surface because it has no lateral support at all.
Or just put the floor mats under the ramps everytime you want to use the ramps.
This is what I use, with silicone vinyl adhered to the bottom. They are called "NRG Slope Box"
I would make my own but this one is just the right size (barely fits) and I got a pair for free.Comment
I like that. Where can i find some?Go buy the cheap $5 rubber floor mats from walmart and cut them up and glue them to the bottom of your ramps.
I would make my own but this one is just the right size (barely fits) and I got a pair for free.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.Comment
I have used them and I must say they are a great jack when put up against the other stock ones I have used.Custom Made Skid Plates For Sale.
http://raceskids.com/Comment
Mine works fine; I use it when I'm adjusting the camber plates and suck. My car is also low enough that most scissor jacks just don't fit.Comment
R.I.P 07/01/09 - 04/23/10 :(
