What size?
  • 88e30is
    • Feb 2007
    • 690
    What size?
    Want to bring out my rims a bit to be flush with the fender flairs.
    Front 1/2 inch
    Rear 1 inch
    What do I need as far as spacers and studs?
  • e30evolution
    West Werks
    • 1888
    custom 3" spacers
    http://www.westwerksauto.com
    • 88e30is
      • Feb 2007
      • 690
      *(Bad words)* Sorry.
      • Lodsin
        • Sep 2006
        • 734
        Maybe try posting up wheel specs and maybe try posting in wheel section?
        • Jand3rson
          • 37587
          Originally posted by 88e30is
          Fuck off.
          Wonderful attitude from the douchebag asking one of the most vague questions possible.
          • ian e30 318is
            • Mar 2007
            • 1808
            measure how far you want your wheels to come out with a tape measure. I measured from the wheel to the fender when i had nonstock wheels on mine. its usually pretty accurate. 20mm = 20mm spacer. pretty simple
            1991 LS1 Swapped 318is
            Instagram:
            https://instagram.com/saltybeast/
            LS Build Thread:
            https://www.r3vlimited.com/board/for...s-e30-ls1-swap
            • 88e30is
              • Feb 2007
              • 690
              Ok...I have the mesurments I just want to know if this will be ok having two different size wheel spacers. I don't mean to have an attitude or be a douchebag but when someone comes at me with an off the wall, ass hole response like that it kind of pisses me off.
              • 88e30is
                • Feb 2007
                • 690
                Sorry, the measurements I have is from the wheel/tire to the fender flare.
                1 inch in the back and 1/2 inch in the front.
                • daniel
                  • 6703
                  you you need spacers of that size, and lug bolts that much longer.
                  http://instagram.com/dslovn.drives
                  • 88e30is
                    • Feb 2007
                    • 690
                    Will it be ok to have different size spacers front vs back?
                    • dashboardmonkey
                      FUCK YOUR WAFFLES
                      • Jun 2008
                      • 6158
                      Yes it will be fine
                      -Andy
                      • 88e30is
                        • Feb 2007
                        • 690
                        Thank you. Sorry I am in a weird mood. Didn't mean to throw around the F U's.
                        • TexasTerp
                          • Jan 2009
                          • 3541
                          Technically he gave you all the information you needed for the question. He stated the depths he wanted to bring the wheels to and the types of hardware possibly involved. What more do you need and why is that vague?
                          stephenbrody.com
                          • dashboardmonkey
                            FUCK YOUR WAFFLES
                            • Jun 2008
                            • 6158
                            U R Welcome
                            -Andy
                            • z31maniac
                              • 17566
                              15mm front and 25 mm rear
                              turnermotorsports.com has the spacers and longer bolts for the front. The 25mm H&R spacers don't need them as you bolt the spaver to the hub then bolt the wheel to the spacer with the stock bolts.
                              www.gutenparts.com
