What on earth is this part thats leaking coolant?
  • jdaigner
    • Sep 2007
    • 98
    I just had a guy replace all my belts on my 1990 325i... soon after, the thermo gasket blew, and i had him replace that... i noticed my coolant light come on tonight, so i opened up the skid plate, and saw the thing at the top of the picture was leaking... or appeared to be leaking from the above area's gasket... What is it ?
  • RedHoodRidah
    • Feb 2006
    • 1096
    Water pump
    92 Granite Silver Vert
    M60B40 5spd
    • jdaigner
      • Sep 2007
      • 98
      Thats what i figured... The guy who changed the belt, and "inspected" the pump, must not have replaced the gasket.
      • RedHoodRidah
        • Feb 2006
        • 1096
        Make sure when you go back that your there to see him work on it and change the parts without half assing anything. I hate some shops for that reason.
        M60B40 5spd
        • jdaigner
          • Sep 2007
          • 98
          yeah... he has 25 years working for BMW, and all kinds of placks on the wall, i figured he would have done it proper...
          Would this leaking coolant, and the coolant getting hotter, cause the gasket on the thermo to blow out like it did ? costing me more money.
          • RedHoodRidah
            • Feb 2006
            • 1096
            If its leaking after it being replace he must of put it on wrong or the gasket was defective or he made it defective. Shouldn't be leaking if it was done right but I could be wrong.
            Get that water pump fixed buy a new unit and gasket and just be there to see it get done or just do it yourself.
            M60B40 5spd
            • Rolla1990
              • 199
              Did the guy also change your timing belt, or just your accessory belts? Usually the water pump is replaced during a timing belt change because it's another "while you're in there" part.
              Turbo M20, MSnS, 38lb, 3" no cat, RPI 12.2", ATS DTC, 240whp/240wtq, Lmnop. www.DonsGarage.net
              • jdaigner
                • Sep 2007
                • 98
                He replaced timing and all other belts... i told him to replace the water pump, he said he looked at it, and no broken plastic, and ran well, so he didn't replace it.
                  • 34847
                  timing belts and waterpump have the same service interval. if one needs replaced, so does the other.
                  fortunately you can still replace it without touching the belt.
                  • jdaigner
                    • Sep 2007
                    • 98
                    How long will it take now, to just get to that pump ? Vs belt and pump.
                      • 34847
                      same time. that's why you usually do both. :(
                      • jdaigner
                        • Sep 2007
                        • 98
                        oh LAME ! Gonna have to have the guy fix it for free then
                        • bmwpower
                          • 1556
                          Anytime you remove the tension on the timing belt, as is needed in a water pump replacement, you need to replace the timing belt as well. This is because the tensioner spring presses against the water pump housing - the tensioner needs to be removed prior to removing the pump.
                          Shame on your mechanic for not replacing the pump.
                          89 325is track project / 05 x5 / 99 M3
                          E30 stuff for sale | Parts I'm looking for
                            • 34847
                            you don't have to remove the tension on the belt to replace the waterpump. Leave the bolt that holds the tensioner alone, remove water pump, reinstall water pump, done.
                            also, the thing about taking tension off the belt and having to replace it is a myth. I've done it. :)
                            • Mtriple
                              • 3139
                              Nice 12,000th post! :mrgreen:
                              Originally posted by Simon S
