Oil has vanished...
Originally posted by BillBraskyThat's like Vlad challenging Chip Foose to a car painting contest.2007 CVPI, stock and slowOriginally posted by acolella76i'm pretty sure 'Phillis' is short for syphilis
1994 tercel, 5efhe swap, i/h/e
1984 t-type, 5.3/th350 swap in progress
My newest addition:
Rebecca Arlene, born 4/19/2013Comment
No I always put my oil into the hole labeled Unleaded.
It all goes to the same place anyways right?Comment
Yes thats correct.
And on a related note last time I filled the engine up with gas, i popped the hood and put the pump in but it only took about a gallon and a half to fill from empty. Now my fuel gauge still reads empty and when i pull the dipstick to check the oil it looks really clean and smells funny. Anyone know whats wrong with my car?Comment
you probably just need to clear it out.
dropping a lit match in usually does the trick.Comment
Looks like I may need a new valve cover gasket. That's my fault, I adjusted the valves a couple times and reused the gasket. However, it's hardly leaking. Not even enough to lose a quart in 4-6 months.
Looks like she's retaining oil well overall though. The level hasn't moved in the past week since I filled it up, so hopefully it's just something minimal.
On a side note: are there repercussions to adjusting your valve clearances too minimal?
I set them to .011 I / .012 E a few weeks back, and it was still running pretty noisey. I set them to .009 I / .010 E this weekend, and it's much quieter, however the idle is a tiny bit rougher.
I'm not sure if this is being caused by the adjustment, or whether the ECU just didn't recalibrate very well after reconnecting the battery. I'm also not getting any read outs from anything with a sensor on my OBC - which is brand new. The clock and Temp work, but that's it. My cluster gas gauge is staying on full also. I replaced the fuel level sender along with the valve adjustment because I was having fuel read issues before, it was all over the map.
Now I get no readings. No OBC fuel level, MPG, AVG MPH, Range.Comment
