Just curious, I wanted to see what it would run me to do this.
I know I would need a E36 318Ti rear suspension (disks calipers ,and rear trailing arms, These are the only ones that can bolt up directly to the E30, with the exception of the E30 M3 which are almost impossible to find. I will also need the E36 front struts with Brakes , E30 top hats to attach to the E30 strut tower and E30 M3 offset bushings.And I need for the front to get the proper alignment it will be 1997 E36 M3 lower control arms . These are the only ones you can use to get the proper wheel spacing and alignment.
Roughly how much could it cost? I know where I would get the aluminum m3 control arms and that would add around 600 to the rest of the parts.
But for everything else what am I looking at?
