E30 Gas tank
  • tyman
    • Feb 2013
    • 27
    E30 Gas tank
    Just wondering if anybody knows if you can fit a fuel tank from an 83 e30 into a 91 e30.
    1991 318is ///S52 Swap Project
    1997 Honda Civic B20 swap (winter beater)
  • roguetoaster
    Biggus Tippus
    • 7830
    The answer is most likely yes, although you may need to reconfigure some wiring/hoses/pump location based on your application.
    Perhaps a new tank would be a better way to go. The eBay $200 or so units are fine.
    • zwill23
      • Jul 2015
      • 615
      Can confirm on the ebay tanks, been using one for the past 5 years and it still looks new inside.
      • efficient
        • Feb 2012
        • 3312
        get a spectra from autozone. fits like oem just doesnt have the drain by the rear passenger side. atleast for a early model it fits well
        • TobyB
          • 5250
          Yes, it fits.
          Yes, you'll need to adapt a bit of the plumbing, as the early tank uses a single in- tank pump and a crossover pipe.
          You'll also need to modify the shielding underneath- but don't delete it completely.
          I too would source a late- model tank for a late- model shell.
          t
