Just bought one: for Spec E30 project
  • Spec E30
    • Apr 2009
    • 40
    '87 325i
    The good:
    $700
    No rust
    Straight body
    Runs Excellent
    5spd
    Shifts smoothly
    New Tires/ Brakes
    The bad:
    vibration under acceleration, worsens over 70mph- driveshaft center support bearing?
    intermittent speedo
    needs shifter bushings
    rough idle
    check engine light on
    right turn signal blinks twice as fast as it should
    Paint
    Interior
  • Dozyproductions
    • Jan 2007
    • 4682
    is that cirrusblau?
    • moatilliatta
      • 6150
      really good pic. I like!
      @Zakspeed_US
      • Intro
        • Apr 2008
        • 196
        The cons are not that bad
        • Spiff325iS
          • Jun 2004
          • 1263
          ^^^ Cons could be fixed easily.
          Great platform to build on also! Great find.
          The Red Dragon V.5 1991 318iS / 2013 F800GT
          "You gotta fix the nut behind the wheel before you fix the bolts on the car"
          • Erik
            • Oct 2005
            • 5370
            Probably just needs a guibo for the acceleration vibration problem.
            -Erik
            Originally posted by 87e30
            • dashboardmonkey
              FUCK YOUR WAFFLES
              • Jun 2008
              • 6158
              If you are going to change the guibo then change the CSB and check your U-joints as well
              -Andy
              • moatilliatta
                • 6150
                Yah, you prolly have a guido twisted up on your drive shaft.
                @Zakspeed_US
                • Tree18is
                  • Mar 2004
                  • 2703
                  nice car. keep that picture as a before because its tits!
                  • Bimmerista
                    • Nov 2005
                    • 5425
                    Nice buy! Just out of curiosity, why a sedan?
                    • Wh33lhop
                      • 11705
                      I like the... reflections off the hood.
                      Nah, your car is almost identical to mine. Nice find, keep us posted.
                      paint sucks
                      • Wh33lhop
                        • 11705
                        Clearly, because sedans are the tits.
                        paint sucks
                        • alpinee30m50
                          • 647
                          dont blinkers blink twice as fast when one of them is out??
                          86 Zinno es
                          M50 inside
                          • Japandrew73
                            • 2164
                            Yep! Change the bulb and knock off one of those cons ;)
                            • shmutzigE30
                              • 1680
                              good project car. have fun wit it
                              AW 89' 325i Vert - SOLD
