325i Touring Turbo +500whp & 325i Touring 24V swap
  • econti
    • May 2014
    • 1152
    #91
    Everything is perfect
    • straight6pwr
      • Sep 2004
      • 3450
      #92
      beautiful color for an e30 touring. well done!
      • iXguido
        • Nov 2009
        • 730
        #93
        wow that is beautiful! very nicely done
        • bmwandhonda
          • 646
          #94
          beautiful touring mate, nice work.
          E30 325i Touring currently under construction.
          http://www.r3vlimited.com/board/show...256444&page=20
          • Osku
            • 104
            #95
            Thanks!
            i got many plans for the future with this car.. But at the moment just enjoying whats done so far
            Airlift,more power,widen the RS etc..
            E30 M50 Touring
            • Osku
              • 104
              #96
              Merry christmas to all you r3v users!
              Thought to write up something here now at holidays when just chilling at home.
              So whats up with the old "black" touring..
              Almost a decade (9years) been gone since i bough it and now its going to get some modifications.
              Just gonna send it
              More pictures CLICK HERE
              Took it all apart
              Body:
              Interior out
              Build rollcage
              Sparvo ProAdv Seats
              SaBelt 6point harnesses
              Put all the interior back that fits on their place,no rear seat at all
              +other minor modifications to make room for "turbo stuff"
              Engine:
              Block:
              M50B25 STD Block
              M52B28 crank,stock M52 pistons
              forged H-beam rods
              all new bearings,pistons rings
              M52 oil pump
              CR: about 9.2:1
              Head:
              Ported Vanos head
              dual valve springs(NV)
              Custom CrMo retainers
              275/10.83mm regrinded cams with modified cam trays
              Ina Hydraulic Racing lifters(8krpm proof)
              ARP studs And cooper ring headgasket
              Engine management:
              MS3X Fully sequential,Cherry Hall Sensors
              Lamborghini COP coils
              Fuel Feed:
              1000cc EV14 injectors
              Walbro 450LPH
              AN8 fuel lines
              high flow fuel rail
              adjustable fuel regulator.
              Air Feed:
              300x600x76mm Bar&Plate type intercooler
              Tial dump valve
              2,5" intercooler piping
              J-spec(swedish company) intake manifold,with 65mm billet throttlebody
              Holset Hx40 Super with #18 twinscroll turbine housing.
              45mm turbosmart wastegate+screamerpipe(to avoid backpressure)
              Self made Twinscroll manifold
              Self made 3,5" stainless exhaust system,with straightflow muffler
              Clutch&Drivetrain:
              Billet flywheel
              765 SRE pressureplate
              E90 320D stock clutch plate
              ZF GS6-37BZ 6speed transmission
              Modified stock driveshaft,Typ188 2,93 LSD
              And then i have to try to control that little increased power output
              So feew updates to driveability.
              Camber/caster adjustable rear axle
              BC Racing DR Track E30 M3 "true coil overs"
              PU bushings
              E34 M5 brakes
              Mini front front rotors316x22mm
              E46 328i rear rotors 294x19mm
              5x120 Bolt pattern
              BBS RC 302 8,5x17" wheels
              E36 steering rack
              And some other little stuff coming up..
              Main reason and use for this car is to break personal goal/record on a standing mile
              Break the speed of 300km/h @1609meters
              Harmfully the hotlinking of photobucket is no longer available ad the fotos are not displayed,new pics are on the imgur so if you want to check out older pics of the black and the red touring.
              Click below
              BLACK
              RED
              Also checkout our crews news on Instagram
              Username teamlehtinenmotorsport
              E30 M50 Touring
              • wworm
                • Dec 2016
                • 1719
                #97
                holy guacamole
                1984 Delphin 318i 2 door
                • vasilis m3
                  • Oct 2015
                  • 54
                  #98
                  Nice work mate!
                  More photo please...we love touring's ;D;D;D
                  • Kershaw
                    • 11822
                    #99
                    That's quite the exhaust. Not worried about smoking the strut mount with that kind of direct heat?
                    AWD > RWD
                    • Osku
                      • 104
                      #100
                      3,5" 304SS all the way from
                      turbine housing.
                      Not worried about the heat at all,im running on ethanol and it burns a lot cooler than a standard gasoline.
                      Theres going to be heat wrap also,manifold and turbine housing also gets a ceramic coating that reduces the surface temperature together so much that when engine is hot you can almost hold your hand on the exhaust pipe.
                      I got the engine running and the megasquirt setted up just before the year changed.
                      Lots of thrust more and motivation to build all that is left still to do at the rest of the winter
                      E30 M50 Touring
                      • Osku
                        • 104
                        #101
                        Originally posted by vasilis m3
                        Nice work mate!
                        Thanks!
                        Check out behind the two links on earlier post,theres a lot of pictures ;)
                        E30 M50 Touring
                        • Osku
                          • 104
                          #102
                          Had a little photoshoot in Fall 2018
                          In February my both tourings were featured in the Finnish customized car magazine.
                          Photos taken by Matti Tirronen (kuvaamasa @IG)
                          Few overall pics of the Boosted one
                          Few enginebay details
                          Breather/catch can and power steering fluid reservoir,coolant reservoir,boost pipes and other all custom made stuff in the engine bay
                          Lets continue with more pictures in next post..
                          E30 M50 Touring
                          • Osku
                            • 104
                            #103
                            Lets continue with the interiors pictures.
                            Full rollcage and the sparco Pro Adv bucket seats,Sabelt 6point harness.. couple custom made stuff here too..
                            And the end of this post more detail pictures from the exterior.
                            CAI for turbo and a proper caution stickers offcourse
                            BBS RC302 wheels
                            And yet one more post to come.. the red Touring got also featured.. ill post a few pics of it too
                            E30 M50 Touring
                            • Osku
                              • 104
                              #104
                              Both together
                              Sitting nicely on 16” RS
                              And heres one rolling shot.. awful weather(rained all day and it was the last summer days when we shooted the cars but still got a decent results from the photoshoot)
                              Unfortunately it looks like i havent uploaded the interior pics from red touring.. gonna fix this and add them in this post later.
                              Feel free to comment what you think about the cars ;)
                              E30 M50 Touring
                              • gnmzl
                                • Jun 2012
                                • 204
                                #105
                                I don't think, I drool.
                                Awesome work and good job finishing your late friend's project car. You are a human being.
                                '85 Alpine Weiß 2-door with m20b30 ground up build
