E30s on 16s - post yours
  • Blackout
    • Apr 2011
    • 4125
    #1486
    ^ I hate you for selling her. lol..
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • dead.broke
      • Apr 2012
      • 120
      #1487
      Death Trap by Logan McWilliams, on Flickr
      My 89 325I by Logan McWilliams, on Flickr
      • dillon7
        • Mar 2013
        • 824
        #1488
        so much win in the last two posts
        Instagram: @dillonmakar
        Build thread HERE
        • zakatak47
          • Feb 2011
          • 100
          #1489
          i think they're OZ F1 cups? haven't gotten any confirmation from anyone tho n barely any info on these. they were plastidipped black when i got em
          any suggestions on what cap to get? OZ or BMW n where to get em from?
          was looking at these http://www.ebay.com/itm/150981428159...84.m1438.l2649. or if i should plasti dip them again but a different color?
          thanks
          • GT BMW E30
            • Nov 2008
            • 2491
            #1490
            Originally posted by dead.broke
            i can dig it.
            • MT325is
              • May 2012
              • 1103
              #1491
              Originally posted by OOMPH!
              I LOVE this! Your rockin my future look!
              Mind Sharing your wheel and tire specs? Spacers? Springs or coils? I can't tell cuz you low.. But not so low.
              Thanks man.
              And the car is beautiful!
              1989 BMW 325is (SOLD)
              1992 BMW 325IC (SOLD)
              1991 BMW 318IS (STOLEN!)
              2017 BMW M2 (WEEKEND WARRIOR)
              1989 BMW 325IC (PROJECT(
              2002 FORD ESCAPE (DAILY)
              • DER E30
                • Sep 2013
                • 2343
                #1492
                Mine, Rota RB 16x8+20 square, with 225/45. 7mm spacer in front. Plastidipped red.
                IMG_4595m by Der E30, on Flickr
                IMG_4564mm by Der E30, on Flickr
                IMG_4581m by Der E30, on Flickr
                IMG_4566m by Der E30, on Flickr
                -Christian
                • jrockbk
                  • Jun 2013
                  • 369
                  #1493
                  I just acquired a set of corvette bbs rs026 have 16x10 et36 all around and I kind of want to keep 2 of them as is and run on car with adapters, btw I'm in a m42 e30, I want to run these wheels with my current suspension setup for DD in NYC though I doubt ill driving them much here, I have bilstien sport inserts and eibach sport springs don't wanna be any lower. can I run wider/taller tire than most ppl I see with 16x10? What's the best size? Will I rub without camber plates? And can I use the wheel in front as well or should I change to shallower lip to make wheel 8.5"-9" wide don't want to disassemble all 4 wheels if I don't have to. Your help and advice is greatly appreciated!
                  • flash 23
                    • 904
                    #1494
                    The 10's you're gonna fit in the rear with "some" work. 20mm adapter will be fine, pull and roll the fenders and roll with a camber (negative). Only 215/45 and or 215/40 will achieve a fitment that works. Anything bigger will eat up your fender. Hope you have a great spring rates to go along with that setup.
                    -welcome to the 10" club!
                    • jrockbk
                      • Jun 2013
                      • 369
                      #1495
                      Don't want to pull and roll fenders either want to be able to return to stock as much as possible no permanent changes for me, how wide can I go in rear without changing anything other than the springs and dampers
                      • dillon7
                        • Mar 2013
                        • 824
                        #1496
                        Well you for sure can't do a 10" wide wheel. Rolling the fenders is just when you roll up the sharp edge of metal on the inside of the fenders so you have a little more room for wheel, and if you do rub, instead of a sharp "L" shaped piece of metal, it's rounded like a "U" shape, and won't cut your tires. So it won't really change the look and its "safer" I guess you could say.
                        That being said, it's going to be hard to make a 16x9 wheel look good with your suspension and no camber and no pull, you're going to have some poke. 16x8.5 would probably look better but that's just my opinion.
                        Build thread HERE
                        • flash 23
                          • 904
                          #1497
                          You'd be able to return to stock just fine even after the pull n roll. It's hardly noticeable if any. It isnt significantly visible unless you get the fender pulled A LOT, which in my experience dont need it. It will work out fine if you listen to my advice. Otherwise you dont need to try if you dont want to.
                          What is your susp set up btw?
                          • OOMPH!
                            • 3487
                            #1498
                            Thanks man.
                            Thank you very much!
                            They started as BBS RS 039, 16x7 et24. They have been redrilled to 4x100, still have the 4x114 bolt pattern as well. Removed the existing lips and added new ones...No spacers used at all.
                            Front 16x8.5 et5 (NEW 2.5" lips) with Nitto NeoGen 205/40
                            Rear 16x9 et-1 (NEW 3" lips) with Nitto NeoGen 205/40
                            I'm on KW coilovers. I DO NOT RECOMMEND THEM. The front collars are plastic and break very easily when pressure is applied especially when your coilover gets stuck with grime/whatever.
                            • jP4
                              • Sep 2012
                              • 168
                              #1499
                              ASA AR1, conti dws 205/50.
                              • Mylch
                                • 390
                                #1500
                                Memory Fab mtechnica's 16x8.5et15 f195/40 20mm spacers r205/40 15mm spacers
                                Drifter??? High Quality Rack Spacers.
