E30s on 16s - post yours
  • bumada
    • Apr 2015
    • 305
    #2116
    Originally posted by dgg15
    this thread is useless without wheel and tire specs.
    16x8 +20 16x9 +15; Kumho Ecsta XS 215/45/16 all around
    Sent from my SM-G900V using Tapatalk
    1989 325i S50 swapped
    2007 4Runner Sport V8
    • litu
      • 835
      #2117
      Yes i have also wonder that in long time....
      https://www.facebook.com/Cry_77_IX-110483784967661
      https://www.instagram.com/cry_77_ix/
      • george graves
        • 19996
        #2118
        I know - for example - these have to be undersized tires. 195/45-16?
        Originally posted by Jim Lepage
        Originally posted by Matt-B
        • litu
          • 835
          #2119
          Here is in my Ix e30...
          Rims 16x8, ET20, at front in 20mm adapter at back is 23mm...
          Tyres are 215/45-16
          • H-M
            • Oct 2014
            • 37
            #2120
            That is some offset you got there Sade! :D
            My 325iX currently with AC Schnitzer Type I 16x7,5 ET25 (205/50R16). BTW, if anyone has access to center caps for these (52mm) please let me know!
            My 325iX
            • dgg15
              • Aug 2015
              • 40
              #2121
              did you roll your fenders? do u rub at all. Whats your suspension setup.
              • bumada
                • Apr 2015
                • 305
                #2122
                Rolled fenders but not sure if it was necessary. I did it for future fitment. Plenty of room for this set up. I'm lowered on fortune auto coilovers. The rear is all the way down, adjusters removed to get lower. The fronts can probably put the frame on the ground. - 2 degrees front camber.
                • litu
                  • 835
                  #2123
                  My iX currently with 16" ->
                  Yes, those are max in ix, maybe need some wider tyre, little rise...
                  Yours looks cool
                  On se hieno noilla AC, mutta mun silmään ne Hartge oli kyllä hienommat
                  • Jim Lepage
                    • Jul 2008
                    • 1138
                    #2124
                    16x9 et12 195/45-16
                    16x10 et07 215/40-16
                    E30S54 - Scale Suspension / Unix Performance Coilovers - 17x8 and 17x9 BBS E50
                    • dgg15
                      • Aug 2015
                      • 40
                      #2125
                      Originally posted by word is bond
                      wow - what wheels are those? 4x100 or fill n drills?
                      tire specs?
                      • dgg15
                        • Aug 2015
                        • 40
                        #2126
                        Originally posted by cabriolet
                        16x7.5
                        tire specs
                        • MPLFoster
                          • May 2013
                          • 1490
                          #2127
                          O.Z. Futura 16x8.5 et24 all around before spacers. Et10 after 14mm spacers. 205/45
                          form.follows.function IG @mplfoster
                          • e30abe89
                            • Oct 2012
                            • 699
                            #2128
                            16x8+11 195/40/16
                            • hankolerd
                              • Oct 2012
                              • 280
                              #2129
                              I will post mine, since when I google searched images for this combo I couldn't find any match.
                              e30 m3 on style 4 16x8 et23 with 18mm spacers
                              205/50-16 front
                              225/45-16 rear
                              Tires are Falken's of sorts.
                              Daniel
                              1990 M3 - http://www.r3vlimited.com/board/showthread.php?t=376104
                              2011 328i Sport Wagon - 6sp Manual, RWD, Sport
                              • Brezzi
                                • Jan 2010
                                • 1630
                                #2130
                                From da sig:
