Progress Is Finally Made - 1988 325iS
    • 37828
    Originally posted by dinanm3atl
    Basic flat roll. Fits like a damn glove! Perfect. No rubbing driving around. Haven't REALLY beat on it but I don't see how there could be any issue.
    Funny, my buddy just did the same suspension, same wheels, and same tire size and he is having rubbing, although very seldom. We rolled his fenders too!
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • bataangpinoy
      • Jul 2008
      • 1636
      gc camber plates take things down about a half inch. and can i have your rear bumper strip and front side markers?
      My feedback:
      http://www.r3vlimited.com/board/showthread.php?t=186328
      http://e30tech.com/forum/showthread.php?t=74911
      Instagram:
      @gears_n_glory
      @functionmotorsports
      • rhett325i
        • Jan 2005
        • 575
        Apparently you can cut a dead coil? Anyone done this? I know it won't change the rate but how much lower is it going to make it? Maybe just take out 1/2 a coil... pics?
        IMO, cutting coils is ftl. If you can get your hands on some drophats for the front, that is the way I would go. This guy is running IE3's with drophats, and the stance is perfect:
        • dinanm3atl
          • Feb 2007
          • 7305
          http://www.r3vlimited.com/board/show...=lug+drop+hats
          Cutting dead coils changes nothing but ride height. The coils literally sit on each other and do nothing.
          That is something I will consider.
          I assume using the GC SpecE30 style with OEM style Bilstein will acheive the lowering? Removing the thick OEM upper strut bearing and replacing with this is what I assume happens and saves a good 1/2 inch...
          Weird. Outside fender lip?
          • RickSloan
            • 2401
            yea i dont want to see this turn into a "cutting your coils is ghetto and stupid thread" you are cutting a dead coil and i think its a fine way to achieve the drop.
            Car looks great so far. I cut 1.5 coils up front and 2 out back on my e12 and will soon cut more, it rides tons better. But they are stock so the rate changed nicely
            Need Illustration or Design work? www.robbiebyerly.com
            • dinanm3atl
              • Feb 2007
              • 7305
              Didn't know about the GC plates dropping me another 1/2in. That could totally get me closer to the goal...
              • Mde36
                • 509
                Originally posted by White325is
                I approve of this. Really needs more drop in the front.
                what he said
                Powered By Ford
                • bataangpinoy
                  • Jul 2008
                  • 1636
                  nice. but for serious i really want your front side markers and the rear bumper strip.
                  My feedback:
                  Instagram:
                  @gears_n_glory
                  • dinanm3atl
                    • Feb 2007
                    • 7305
                    I'll prolly post it all up for sale when I get the plastics on.
                    • fiftytakedowns
                      • 2460
                      This work for the rear too?
                      [/url]
                      Team USA Wrestling 67KG
                      • bwanac
                        • 3354
                        not loving the slip streams, but looking fresh otherwise.
                        • Philo
                          Ich esse kleine Kinder
                          • 3334
                          Looks good.
                          I'm not sure who informed you on the "dead coil" thing but that is not the case. It will increase the spring rate, decrease the re-sale value, and shorten your strut travel. I am against cutting springs.
                          Originally posted by craz azn
                          I ended up getting used H&R Races and stock Bilstein Sports from ebay this spring. It was really high at the front after I installed them, so I did the one coil chop method, which to my dismay increased the spring rate by a fair bit (anyone who says its a dead coil is full of shit; I tested before and after myself in a spring rate tester).
                          As mentioned in other threads, you should have gone with H&R race as it would have given a much better stance vs. IE3's. I highly suggest the GC camber plates. They lower the front (more than 1/2"), give you more strut travel, and allow you to adjust camber/caster.
                          Anywho, keep up the good work. The car is coming along mighty fast. :up:
                          Side note: Idiot. \/
                          -tim
                          Originally posted by Jordan
                          I like the stance
                          • dinanm3atl
                            • Feb 2007
                            • 7305
                            H&R Race though doesn't have enough rate in my opinion. If they lower more than 1/2in I will order those tomorrow. I will call GC to make sure I get the proper ones.
                            • dinanm3atl
                              • Feb 2007
                              • 7305
                              Rate... like they are too soft for how much they lower. In every car from E36 to E30 to VWs to everything... too soft for the drop.
                              On the M3 I had the bilsteins revalved and shortened so they could actually work properly with them.
                              Pics with IE3 and GC plates?
                              • Philo
                                • 3334
                                IE3s and Races supposedly have the same rate.
                                Calling GC is the only way to go. They are $300 though, so it's not like they are cheap.
                                Found it.
                                -tim
                                I like the stance
